subsonic inlet-exit boundary conditions
Like Tree1Likes
  • 1 Post By sylvain
Old   July 7, 2005, 16:05
Default subsonic inlet-exit boundary conditions
Cfd Student
Dear CFD-Gurus, I need info/paper explaining the details regarding the implementation of subsonic inlet/outlet BC. Any help is greatly appreciated. Best regards.
CFD Student
Old   July 7, 2005, 23:19
Default Re: subsonic inlet-exit boundary conditions
sylvain
Subsonic flow means that 2characteristic lines are positive and one is negative (a, u+a, u-a). Consequently you need 2 upstream informations and one upstream:
AT the inlet: the 2 upstream information are for example u=uinfinity and T =Tinfinity. The downstream information needs to be extrapolated
At the outlet: 2 extrapolated information: for example du/dx=0 at the outlet and dT/dx=0 at the outlet and 1 downstream information for example P=P backstream
If you don;t understand review the theory of characteristics.
Sylvain
LigouAG likes this.
Old   July 8, 2005, 19:36
Svetlana Sushchikh
For addition to previous reply:
you can read how to inplement BC for example at
Culbert B. Laney " Computation GAsdynamic" , Cambridge Univ. Press, first 1998.
Sveta
Old   July 10, 2005, 01:28
Cfd Student
Thanks a lot for all...
CFD Student.
Old   July 13, 2005, 01:45
Dominic
How is it in Multi-D ?
Old   July 26, 2005, 07:14
enis
hi slyvian,
what did you mean by "P=P backstream" at the outlet. should P_backstream be a certain number? or P_{i+1}=P_i ?(as in continuative boundary condition).
thanks.
enis
Old   July 26, 2005, 10:16
sylvain
When the flow is subsonic, you have two characteristic with a positiv slope and one with a negative slope. (assuming a velocity being positive). Hence, one of the boundary condition needs to be specified outside of the domain. Let's say you want to specify the backstream pressure as your outside of the domain condition. Then you can specify P=Pbackstream.
If you are considering an external flow then Pbackstream=Patmospheric (remember that along a characteristic line the pressure is constant). If you consider an internal flow then it depends on the type of problem I guess. Hope it helps. If it sounds obscure to you check out the theory of characteristics, and how the eigenvectors and eigenvalues are to be calculated and how they relate with CFD problems
Sylvain
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
Boundary conditions: inlet and outlet aline OpenFOAM 7 June 29, 2010 03:45
Inlet Boundary Conditions Fernanda Main CFD Forum 3 January 26, 2007 03:09
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 01:54
