Help:Finding sources of error
Old   July 25, 2005, 21:31
Default Help:Finding sources of error
Quarkz
I've written a NS FVM solver. I'm using Ghia's lid driven cavity result to test for accuracy.
The u values for the same grid size typically have difference of less than 2%, except one which is different by 20% (0.003 vs 0.004).
However, the v values typically have difference of 2-5%. I'm wondering if that is acceptable...
I'm trying to find out the source of error. I was thinking of wrong implementation of BC but then my u values will not be so close then. Hence I suspect that there are some careless mistakes in my v,y BC. Is that logical since my v values differs by 2-5%?
Thank you very much
Old   July 26, 2005, 10:00
Default Re: Help:Finding sources of error
M
Firstly, if You would like to get help here, please give description of Your solver.
NS FVM solver rather wide formulation
When I had the same problem, I fixed it having found a mistake in high-order discretization schemes of convective terms (there was a bug).
With BC there have not to be problems
U and V all zero except upper wall where U=1.
As a rule on the fine grid (300x300) with HLPA scheme You should obtain excellent results
All that from my experience with SIMPLE solver on staggered as well as colocated grids
Old   July 26, 2005, 10:03
M
By the way, how do You get Ghia's velosity distribution?
Old   August 2, 2005, 04:29
quarkz
what do you mean by how to get Ghia's velosity distribution?
the velocities are given in his paper in journal of computational physics 1982 48 p387
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
