Lagrangian Approach
Old   August 2, 2005, 11:03
Default Lagrangian Approach
Biswajit Sarkar
I want know about the difference between the lagrangioan approach and eularian approach. I also know anout how can I have some literature about these two basic approach?
Old   August 2, 2005, 11:13
Default Re: Lagrangian Approach
diaw
Simply stated:
Langrangian... moving reference frame Eulerian... fixed reference frame
Most CFD software adopts the Eulerian approach, although the derivation of the Navier-Stokes equations can use either approach & then convert between each, as required.
Versteeg has an excellent book.
diaw...
Old   August 4, 2005, 12:19
Biswajit Sarkar
Hi, anybody can send me some preliminary soft material so the I can get initiated with CFD. Regards, Biswajit Sarkar
Old   August 4, 2005, 13:42
Vinod Dhiman
What kind of soft material do you need. Do you need a code, or some algorithm to write your own code. Codes you can download. There are many sites on which codes for CFD are available. Usually most of them use Eulerian approach.
Lagrangian Approach Biswajit Sarkar Main CFD Forum 9 January 25, 2013 08:31
Euler-Euler vs. Lagrangian particle tracking for biomass pyrolysis in a rotary kiln audrey Main CFD Forum 0 February 22, 2011 12:09
lagrangian vs eulerian approach leopoldo luongo CFX 1 June 19, 2006 10:12
tutorials of lagrangian approach Luca Stabile FLUENT 0 January 21, 2006 07:20
Statistical Approach for Lagrangian Two Phase Model Hesham El-Batsh Main CFD Forum 0 November 20, 1998 09:20
