Advanced use of LES
Old   August 6, 2005, 14:36
Default Advanced use of LES
Maine
I was wondering in everyones opinion, what is the most advanced use of LES for an engeering application?
In particular what about for gas turbine maybe with or without combustion?
Old   August 6, 2005, 19:13
Default Re: Advanced use of LES
MT
How about "WEATHER PREDICTION"
Old   August 7, 2005, 12:17
Vinod
Yeah, weather predictions related to fluid flow is one of the most prominent field driving LES.
Vinod Dhiman
Old   August 7, 2005, 14:53
Maine
is weather prediction not quite a large scale phenonemon though, i.e. it doesnt need very fine grids like you might need in as a more enginnering application???
also in weather i suppose the boundary conditions are rahter simplified. isnt it harder when we have walls and things???
Old   August 7, 2005, 15:43
noName
Weather prediction was the first application of LES in the 1960's. See the seminal paper:
J. Smagorinsky. General circulation experiments with the primitive equations, i. the basic experiment. Monthly Weather Review, 91:99, 164, 1963.
Old   August 7, 2005, 20:29
azmir
In my opinion, it takes too long to be practical in an industry. Recent work by Chan-Moon Jang on subsonic fan for a y+ inside the sublayer took 2.5 months on a supercomp to complete.
Old   August 8, 2005, 09:38
Vinod Dhiman
Hi
System related to weather may have very simpler boundary or intial conditions, but the turbulence is very complicated in this system. In machines you have limited scales, which are important, but in Atmospheric sciences, almost every scale is equally important. That's why LES.
Vinod Dhiman
Old   August 12, 2005, 00:16
yuan
There is no 'most advanced use' of LES for engineering application. TYou may adopt the classical Smagorinsky SGS-model and the dynamic procedure. The numerical scheme must be at least of second order and the nonlinear term is well calculated. In addition, great attention should paid to mesh resolution. I use LES for some engineering design. The headache is the limitation of low Renolds number(Re~10^4). The cost is not as high as imagined. Actually you may succeed using a personal computer.
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
Differences between a laminar code and a les one ben Main CFD Forum 9 February 16, 2005 23:40
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 08:10
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 09:58
