August 8, 2005, 08:45 |
Kolmogorov scale .... LES
I am doing some LES of a reacting flow and I need to calculate some values. How can I calculate the Kolmogorov timescale and the Kolmogorov Reynolds Number? Also how can I calculate the dissipation rate (epsilon)? Thanking you all. |
August 12, 2005, 00:01 |
Re: Kolmogorov scale .... LES
I guess you need read a textbook. Select large scales, estimate the dissipation scales by using the Komogorov relations and then estimate epsilon.
July 2, 2015, 19:48 |
Hello LESer,
Did you find how to calculate kolmogorov length scale in LES? I really appreciate if you could give me some help on this. Thanks, |
July 3, 2015, 03:38 |
Filippo Maria Denaro
Rep Power: 71 |
there is no Kolmogorov scale in LES ! the smallest scale is defined by the filter lenght, not by the molecular viscosity and lies in the inertial subrange.
July 3, 2015, 05:36 |
FMDenaro thank you very much for your reply. Can you tell me a way to calculate this smallest length scale? I just need a way to calculate something similar to kolmogorov length scale? Can I write a user defined function for kolmogorov length scale maybe? If you could give me some help on this I really appreciate it.
Thank you very much |
July 3, 2015, 05:54 |
Rep Power: 71 |
Kolmogorov scale is dictated by the physics of the problem.
LES provides the smallest scale at about twice grid step size. That has nothing to do with kolmogorov scale |
July 3, 2015, 06:01 |
FMDenaro, thank you very much for your reply. Is there any way I can calculate and see that smallest scale in Fluent? I really appreciate your help. I just need to calculate something corresponding to kolmogorov length scale in LES. Thanks a lot.
Kolmogorov turbulence time scale | iko | FLUENT | 2 | July 15, 2008 10:04 |
LES inlet length scale | f.neilson | Main CFD Forum | 0 | January 31, 2005 13:26 |
Length scale separation in LES | Ray | Main CFD Forum | 1 | June 7, 2002 08:50 |
Kolmogorov scale | T.Misawa | Main CFD Forum | 2 | December 12, 2001 04:02 |
Kolmogorov scale of atmospheric BL | J. Kim | Main CFD Forum | 0 | December 8, 2000 11:45 |
