February 14, 2012, 07:32 |
Refrences about transient flow
Amin Shariat KHah
Rep Power: 15 |
Hi to everyOne
Can anybody introduce me some good refrences about simulation of transient flows? TNX very Much |
February 14, 2012, 14:08 |
Amin Shariat KHah
Rep Power: 15 |
No any answer?
February 14, 2012, 15:38 |
cfdnewbie
Rep Power: 20 |
February 14, 2012, 16:01 |
Filippo Maria Denaro
Rep Power: 71 |
if you need a test-case, it exists an analytical benchmark of a 3d incompressible flow on periodic box
February 14, 2012, 16:06 |
Amin Shariat KHah
Rep Power: 15 |
Thanks Dear cfdnewbie
I have some problem for undarstanding what should I do with Neuman B.C. in flow for example in flow between 2 plates in each step after solving we see continuity is not satisfied I can't realize how should I correct Continuity without changing transient answer |
February 14, 2012, 16:10 |
Amin Shariat KHah
Rep Power: 15 |
Dear Filippo
Thanks for your reply As I said I can,t understand some basic concept I solve first step and I see continuty is not satisfied now what should I do? my BC is Neumann and I have a fix value to itterate and reach it I don't know how itterate to doesn,t going forward in time |
February 14, 2012, 16:15 |
#7 | |
Rep Power: 71 |
are you using a fractional-step/projection method? |
February 14, 2012, 16:16 |
Amin Shariat KHah
Rep Power: 15 |
Absolutly yes
February 14, 2012, 16:17 |
#9 |
Amin Shariat KHah
Rep Power: 15 |
sorry: my BC is Neumann and I DONT have a fix value to itterate and reach it |
February 14, 2012, 16:20 |
#10 |
cfdnewbie
Rep Power: 20 |
February 14, 2012, 16:21 |
#11 | |
Rep Power: 71 |
V* = Vn+1 + grad phi Taking the divergence of both sides you get the "pressure equation", the BCs are obtained by projecting the decomposition along the normal unit vector. The problem is well posed and has a unique solution a part a constant. If you verify that the divergence-free constraint is not verified at the end of the steps, you probabily have fixed wrong BCs. |
February 14, 2012, 16:23 |
#12 |
Rep Power: 71 |
February 14, 2012, 16:27 |
#13 | |
Amin Shariat KHah
Rep Power: 15 |
my problem I want know this basically can you introduce me a refrence to study much more in detail? |
#14 |
cfdnewbie
Rep Power: 20 |
thank you very much, I don't have access to the paper from home, but will check it out tomorrow. From the first page it looks like what they are doing might be a manufactured solution method (adding a forcing source term), is that asssumption correct?
February 14, 2012, 16:34 |
#15 | |
Rep Power: 71 |
you will see that the solution is unsteady and divergence-free in such a way that the time derivative, convection, pressure gradient and diffusion in the momentum equation balance each others |
February 14, 2012, 16:37 |
#16 | |
Rep Power: 71 |
There are many recent papers on this topic you can read after you have basic knowledge of the projection method |
February 14, 2012, 16:43 |
#17 |
Amin Shariat KHah
Rep Power: 15 |
Thanks Dear Filippo
Unfortunately some question haven't answered in any book and the key is finding someOne that have some works in this fields |
February 14, 2012, 16:47 |
#18 | |
Rep Power: 71 |
I have also some of my papers discussing the property of the Hodge decomposition in the projection method, you can find them on the IJNMF |
February 14, 2012, 16:56 |
#19 | |
Amin Shariat KHah
Rep Power: 15 |
I saw in papers that neumann BC cause problem in continuty but I cant remember that paper unfortunately if I understood good you are saying if everything be ok continuty should be satisfied even in case with neumann BC? Have you any paper using this method in a simulation case? |
February 14, 2012, 17:04 |
#20 | |
Rep Power: 71 |
the issue is not simple to explain in few words ... you need to distinguish if you are using an exact projection method or an approximate projection method. In the latter case you do not satisfy exactly div V =0 but only up to the magnitude of the local truncation error. Try to read: F.M. Denaro, On the application of the Helmholtz-Hodge decomposition in projection methods for the numerical solution of the incompressible Navier-Stokes equations with general boundary conditions, Int. J. Num. Methods in Fluids, 43, 2003 F.M. Denaro, A 3D second-order accurate projection-based Finite Volume code on non-staggered, non-uniform structured grids with continuity preserving properties: application to buoyancy-driven flows,Int. J. Num. Meth. Fluids, 52, 4, 393-432, 2006. |
Problem with transient solution of flow past a row of cylinders | jostanek | Main CFD Forum | 0 | January 6, 2010 12:16 |
TRANSIENT ANALYSIS OF JET FLOW | shriramjegan | FLUENT | 0 | July 28, 2007 12:04 |
transient compressible flow simulation-urgent | JSM | FLUENT | 0 | April 26, 2007 01:51 |
transient compressible flow problem (urgent plz) | jehanzeb | FLUENT | 5 | August 3, 2004 08:04 |
PhD in turbulence | Hans | Main CFD Forum | 14 | October 8, 2001 03:03 |
