CFD of gas Turbine blade
Like Tree1Likes
  • 1 Post By Ali Raza Abid
Old   September 12, 2011, 14:16
Red face CFD of gas Turbine blade
Ali Raza
Ali Raza Abid is on a distinguished road
I want to do CFD analysis of a Gas Turbine blade on FLUENT software the known parameters are
Inlet Temp. = 900 C
Inlet Velocity = 700 m/s
Mass flow rate of air = 450 ton/hr
Inlet pressure = 8 bar
Outlet temp. = 600 C
outlet Pressure = 3 bar
I have generated the Grid in GRIDGEN software
Kindly guide me what boundary conditions,inlet conditions and solvers etc i should use to solve my case?
yasin.kb likes this.
Ali Raza Abid is offline   Reply With Quote
Old   September 12, 2011, 14:21
Ali Raza
Originally Posted by Ali Raza Abid View Post
I want to do CFD analysis of a Gas Turbine blade the known parameters are
Inlet Temp. = 900 C
CFD analysis of gas Turbine Blade
Old   September 12, 2011, 14:34
Red face CFD of gas Turbine Blade
Ali Raza
Inlet Temp. = 900 C
Old   September 12, 2011, 15:24
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
http://www.cfd-online.com/Forums/cfx...machinery.html
check reply no 5 with real results in pdf file
Far is offline   Reply With Quote
Old   September 12, 2011, 15:32
Far
Sijal
dont you have NGV with rotor blade? if no then you have to specify the angle at inlet (axial and tangential components with radial component = 0; specify the sign of axial and tangential components in accordance of right hand rule)
at inlet specify total pressure and total temperature and at outlet specify the mass flow outlet or corresponding static pressure (which produces the required mass flow rate)
give fluid the required rpm and specify axis direction as per right hand rule. choose x,y or z (with value 1 or -1) as your axis of rotation
keep the default conditions for hub and blade and for shroud : specify it as rotating wall with zero rpm in inertial reference frame
also use the periodic boundary condition for the planes (two identical planes with identical mesh) between adjacent blades
Old   September 12, 2011, 15:36
Ali Raza
Actually i just want to do analysis of a single blade then what conditions i should use? please clear me sorry for inconvenience i m a bit new in CFD
Old   September 12, 2011, 15:49
Far
Sijal
inlet
the total pressure
total temprature
flow angle (from NGV)
outlet
static pressure
Old   September 13, 2011, 01:55
sabin's Avatar
sabin mathew
sabin is on a distinguished road
Send a message via Skype™ to sabin
Since you want to do analysis of single blade, first thing you have to do is control volume creation for single blade. I.e separate out your blade from other blades in the problem.
2nd thing will be boundary condition specification. You can specify inlet and outlet according to what you know. Since you are doing single blade analysis common surfaces of blades should be specified as 'periodic boundary condition'. Hope it is clear to you.
All the best
Sabin Mathew
sabin is offline   Reply With Quote
Old   September 14, 2011, 13:56
Ali Raza
ok i will periodic boundary conditions kindly guide me what initial conditions and solvers i should use in FLUENT V 6.4?
Old   February 18, 2012, 05:04
JAGAN RAJ
jaganraj is on a distinguished road
hi,
i need a coordinates to study the analysis process for turbine blades. please give me the link to get them.
jaganraj is offline   Reply With Quote
blade to blade 2D CFD Hina Main CFD Forum 0 December 30, 2010 09:14
blade analysis of gas turbine Fayyaz Husain Main CFD Forum 1 March 3, 2010 01:13
Can anybody help me? (Turbine blade simulation) Amisa CFX 3 January 7, 2008 03:24
FEA of gas turbine blade and disc sureee Main CFD Forum 3 March 15, 2006 04:59
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
