CGNS fortran code compiling with intel visual fortran xe |
April 3, 2012, 11:26 |
Dokeun, Hwang
Rep Power: 16 |
Dear ...
I compiled cgnslib_3.1.3 using CMake-gui(ver 2.8.7) with generator 'visual studio 9 2008' and there were some options as follows. I'd like to know what other Names unchecked in Value colume are Should I check ENABLE_FORTRAN in order to use fortran code for my program? However, when I did configure & generate with this option, I couldn't build "cgns.sln" Should I check BUILD_CGNSTOOLS in order to use cgnstools? ================================================== ============ Name __________________________________________________ Value ================================================== ============ BUILD_CGNSTOOLS___________________________________ ___ □ CGNS_BUILD_SHARED_________________________________ ___v CGNS_USE_SHARED___________________________________ ___v CMAKE_BUILD_Type__________________________________ ____Release CMAKE_INSTALL_PREFIX______________________________ ____C:/Program files/cgns ENABLE_FORTRAN____________________________________ ____□ ENABLE_HDF5_______________________________________ ____□ ENABLE_LEGACY_____________________________________ ____□ ENABLE_LFS________________________________________ ____□ ENABLE_SCOPING____________________________________ ___□ ENABLE_TESTS______________________________________ ____□ ================================================== ============ With default option, I could build cgns.sln by MS visual studio and got some files as follows in debug folder "cgns.idb, cgns.lib, cgns.pdb, cgnsdll.dll, cgnsdll.exp, cgnsdll.idb, cgnsdll.ilk, cgnsdll.lib, cgnsdll.pdb" What should I do with these files in order to test fortran files described in CGNS User's Manual? Last edited by dokeun; April 4, 2012 at 13:25. Reason: Issue was changed. |
April 5, 2012, 21:01 |
got solved
Dokeun, Hwang
Rep Power: 16 |
Hi there.
After few days of efforts, I somehow installed the library & cgnstools. When I first tried to install it, I didn't even know what makefile, cmake mean. And README and other explanation files included were not enough for me. Even though this looks clumsy a little, it works. So I'd like to share my experience hoping that it can be a help. And I hope someone presents more refined solution. PC environment is as follows.. OS : windows 7 Program : MS Visual Studio 2008, Intell Visual Fortran [How to install cgns library and cgnstools] 1. Download lastest source file(ver. 3.1.3) from http://cgns.sourceforge.net/download.html 2. Download HDF5 from http://www.hdfgroup.org/HDF5/release...n5.html#obtain and install it. => I'm not sure if it is necessary but I followed an install guide in the cgns sources => I'm not sure waht you should install. But I choosed HDF5188-win32-static.zip 3. Download Tcl from http://www.activestate.com/activetcl/downloads and install it. => In my case, I installed it to c:\Program files\Tcl => Regist ...Tcl\include as include < environment variables ...Tcl\lib as lib < environment variables 4. Unzip cgnslib_3.1.3.tar. wherever you want =>then some files and directories will be shown 5. Excute "Visual Studio 2008 Command Prompt" from Start>Miscrosoft Visual Stuio 2008>Visual Studio Tools =>cmd won't work if you don't set path or something in environment configuration. 6. Go to the ...\src under the directory you unzipped cgnslib_3.1.3 => ex) c:\Program files\CGNS\cgnslib_3.1.3\src>__ 7. type ..\src>configure.bat -lfs -ifort -tcl [tcl directory] -install [install directory] => here, [tcl directory] is where the tcl is installed. ex)c:\Progra~1\Tcl => [install directory] is where a result will be installed. ex)c:\Progra~1\CGNS => Caution! There should not be any blanck when those directories are typed. Type "Progra~1" instead of "Program files". 8. type ..\src>nmake all => In my case two error messages were given but those didn't matter. I just typed this command one more. 9. type ..\src>namke install => Then 2 or 4 folders including files will be installed to [install directory] => If you have no problem, then there should be 4 directories. include, bin, share, lib => In my case there were just 2 folders, include, lib. so I executed. ...src\sgnstools>cgconfig.bat ...src\sgnstools>nmake install ------------------------------------------------------------------------------------------------------------------------------------------------------------- A. Regist following folders in MS Visual Studio>Tools>Options>Intel(r) VF>Compiler ...>CGNS>lib ...>CGNS>include => But, when I compiled fortran code from example codes, I had to include "..CGNS\lib\cgns.lib" as resource file in MS Visual IDE. Refer attached image. B. Just execute batch files in the folder, ...CGNS>bin for cgnstools ------------------------------------------------------------------------------------------------------------------------------------------------------------- Last edited by dokeun; April 9, 2012 at 08:12. Reason: error fixing |
Comparison between C/C++ and Fortran? | rick | Main CFD Forum | 45 | September 6, 2011 00:52 |
CFD Code with Fortran | murat | Main CFD Forum | 0 | October 11, 2009 17:05 |
Intel Fortran and CFX 11.0 | Rogerio Fernandes Brito | CFX | 4 | November 11, 2008 00:27 |
visual fortran | Monica | Main CFD Forum | 1 | August 28, 2004 20:45 |
Error when compiling user fortran | Mads Bang | CFX | 1 | October 8, 2002 11:47 |
