Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Aspect ratio in orthogonal mesh
Old   June 14, 2014, 10:33
Question Aspect ratio in orthogonal mesh
Blaž Mikuž
bmikuz is on a distinguished road
I have a question related to discretization of Navier-Stokes equation in finite volume method. I would like to clarify myself the effect of large aspect ratio (AR) to accuracy of the results.
In complex geometries large AR of the mesh cells could give rise to high skewness of cells, which introduce some numerical errors related to interpolation of fields to faces. This is evident if the mesh is non-orthogonal whereas for the orthogonal mesh there is no such error even if AR is large. Am I right?
So, why should AR be kept low (about 1.05 or lower) in meshes used for LES simulations? Is this requirement related to numerical error of discretization or not?
Thanks!
bmikuz is offline   Reply With Quote
aspect ratio, discretization errors, les grid, navier-stokes
Mesh Aspect ratio and Angle star Mesh Generation & Pre-Processing 3 September 7, 2013 02:24
Grid Aspect Ratio harishameed33 Main CFD Forum 1 August 11, 2012 22:35
[ANSYS Meshing] How to Control Aspect Ratio in Ansys meshing mecbe2002 ANSYS Meshing & Geometry 0 May 28, 2012 07:56
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Visualise CFX Mesh Aspect Ratio? Ianto CFX 7 November 13, 2008 04:05
