April 6, 2016, 15:34 |
Meshing an impeller
Kieron
Rep Power: 11 |
I am trying to mesh an impeller however I'm having trouble trying to figure out the correct procedure for this. Would anyone be able to recommend how I should be meshing an impeller, the cone shape and perhaps the fins.. At the minute I can't just mesh the cone shape, at least one of the fins is also selected when trying to mesh the cone individually. I am using NX10. https://gyazo.com/4b3f99f9f702e70dc9044092a9e8f8a4 - problem I'm explaining, fin gets selected with the cone. https://gyazo.com/b5974df55927edf4c5b8697fe0db7510 - sloppy mesh on cone as a result of each fin being attached to the cone, meaning it overlays the mesh Regards |
June 26, 2017, 01:51 |
Mesh Expert
sila
Rep Power: 12 |
I can Help you. let me know if you have the requirement still now. Regards, Sila |
[ICEM] Hexa meshing of impeller and diffuser assembly | Nitin Dewangan | ANSYS Meshing & Geometry | 14 | September 13, 2016 09:41 |
[TurboGrid] impeller meshing | tmeysam92 | ANSYS Meshing & Geometry | 2 | March 13, 2016 00:25 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ICEM] meshing an impeller | tmeysam92 | ANSYS Meshing & Geometry | 4 | May 24, 2014 01:39 |
[ANSYS Meshing] Impeller Meshing | rvl565 | ANSYS Meshing & Geometry | 6 | July 29, 2013 16:20 |
