May 21, 2014, 09:15 |
meshing an impeller
tmeysam92
Rep Power: 14 |
Hi all,
i want to mesh an impeller with icem cfd. i have removed the blade parts from impeller, because i want to simulate flow around the blade, and i have to mesh all of them not using periodic b.c. i have worked with icem cfd but i am not very good at meshing with that. so is there any video that shows meshing an impeller with icem cfd? or other files than can help me. thanks in advance. |
May 22, 2014, 01:30 |
the geometry
tmeysam92
Rep Power: 14 |
in below figure i attached the geometry.
May 22, 2014, 01:31 |
tmeysam92
Rep Power: 14 |
the geometry
May 23, 2014, 04:55 |
SanS
Rep Power: 17 |
so you have the geometry. Now start meshing, its quite similar to the tutorial " tetra/prism mesh for an aorta". Follow the same steps.
May 24, 2014, 01:39 |
tmeysam92
Rep Power: 14 |
[ICEM] Meshing Centrifugal Impeller | Bellmo | ANSYS Meshing & Geometry | 8 | November 27, 2018 13:02 |
[ICEM] Hexa meshing of impeller and diffuser assembly | Nitin Dewangan | ANSYS Meshing & Geometry | 14 | September 13, 2016 09:41 |
[ICEM] Suggestions regarding meshing of a centrifugal impeller | S.Tushar | ANSYS Meshing & Geometry | 0 | January 31, 2014 01:22 |
[ANSYS Meshing] Impeller Meshing | rvl565 | ANSYS Meshing & Geometry | 6 | July 29, 2013 16:20 |
[ICEM] Meshing a centrifugal compressor impeller | Mitpostdoc | ANSYS Meshing & Geometry | 8 | February 25, 2011 10:51 |
