Home > Forums > Special Topics > Mesh Generation & Pre-Processing
2D rectangle in Gmsh -naming physical lines
Old   January 16, 2018, 11:49
Default 2D rectangle in Gmsh -naming physical lines
Ruby Marshall
marshallr is on a distinguished road
As part of a simulation I am trying to generate a 2D rectangle in Gmsh with significantly more elements in one direction than the other.
The aim is to use it with Su2. Therefore I want to define which lines are the 'left', 'right', 'upper' and 'lower' to enable my boundary conditions to be applied by the solver.
However there is a syntax error for the lines under '//Boundaries'
Any suggestion as to how i fix this?
Thank you
mesh code:
Point(1) = {-1, 0.1, 0, 1.0};
Point(2) = {1, 0.1, 0, 1.0};
Point(3) = {1, -0.1, 0, 1.0};
Point(4) = {-1, -0.1, 0, 1.0};
Line(1) = {1, 2};
Line(2) = {2, 3};
Line(3) = {3, 4};
Line(4) = {4, 1};
Line Loop(1) = {1, 2, 3, 4};
Plane Surface(1) = {1};
Transfinite Line {3, 1} = 2000 Using Progression 1;
Transfinite Line {4, 2} = 5 Using Progression 1;
Transfinite Surface {1};
Recombine Surface {1};
//Boundaries
Physical Line (“upper_wall”) = Line(1) ;
Physical Line (“lower_wall”) = Line(3) ;
Physical Line (“left”) = Line(4) ;
Physical Line (“right”) = Line(2) ;
Physical Surface (“tube”) (1);
marshallr is offline   Reply With Quote
Old   February 10, 2018, 04:53
tomm450 is on a distinguished road
This should work
//Boundaries
Physical Line ("upper_wall") = {1};
Physical Line ("lower_wall") = {3};
Physical Line ("left") = {4};
Physical Line ("right") = {2};
Physical Surface("tube") = {1};
I don't know if it's the web site font but Gmsh doesn't recognize the quotation marks of the geo file you post
tomm450 is offline   Reply With Quote
2d mesh, boundaries definition, gmsh, gmsh syntax, su2 mesh
Gmsh does not ouput SU2 markers from physical surfaces stewels SU2 4 May 17, 2023 05:15
[Gmsh] Nasa Nozzle: Plot 3D -->gmsh -->fluent - no physical groups Nico89 OpenFOAM Meshing & Mesh Conversion 1 June 14, 2016 05:40
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
