April 4, 2020, 10:24 |
Apparent mesh overlap in Gmsh
Aashish
Hi I am trying to create a simple geometry and mesh it. I have attached both the image and the .geo (the extension is .txt because cannot upload .geo) file for Gmsh. In the image, there seems to be an overlap in the mesh between two regions as pointed by the arrow. I did a simple check with a Python script and could not find any duplicate elements. Is this just visualization problem by Gmsh or is there something wrong with my mesh. Thank you for your help.
April 7, 2020, 09:17 |
Mikko
Rep Power: 12 |
If you take a close look at the points you are defining. Some of them are missing the z-coordinate and therefore the gridsize is used as a z-coordinate. You can also observe this visually, some of the coordinates are not on the same z-plane. Best, Mikko |
April 7, 2020, 17:40 |
Thank you Mikko
#3 | |
Aashish
Thanks, Aashish |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
GeometricField -> mesh() Function | Tobi | OpenFOAM Programming & Development | 10 | November 19, 2020 11:33 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[Gmsh] gMsh instead of blockMesh for base mesh, then snappyHexMesh | sazabi2001 | OpenFOAM Meshing & Mesh Conversion | 0 | February 23, 2017 12:00 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
