Define a position in terms of the domain size |
October 26, 2020, 11:38 |
Luis Felipe Lσpez
Rep Power: 6 |
Hi all!
I have a custom library where I want to define a custom position in terms of the domain lengths. For example, I want something like customPosition = (0.1*Size_in_x, 0.5*Size_in_y, 0.0) I tried to do something like this: Code:
volVectorField initialFlameletPosition ( IOobject ( "initialFlameletPosition", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), mesh, dimensionedVector(dimLength, ( 0.1*max(mesh.C().component(0)) 0.5*max(mesh.C().component(1)) 0.) ) ); Code:
In file included from /opt/openfoam8/src/OpenFOAM/lnInclude/postProcess.H:105:0, from spflameletFoam.C:53: ./createFields.H: In function int main(int, char**): ./createFields.H:368:22: error: expected primary-expression before ( token dimensionedVector(dimLength, ( 0.1*max(mesh.C().component(0)) 0.5*max(mesh.C().component(1)) 0.) ) ^ ./createFields.H:368:67: error: expected ) before numeric constant dimensionedVector(dimLength, ( 0.1*max(mesh.C().component(0)) 0.5*max(mesh.C().component(1)) 0.) ) ^~~ ./createFields.H:369:2: error: expected ) before ; token ); ^ In file included from spflameletFoam.C:60:0: createFields.H:368:22: error: expected primary-expression before ( token dimensionedVector(dimLength, ( 0.1*max(mesh.C().component(0)) 0.5*max(mesh.C().component(1)) 0.) ) ^ createFields.H:368:67: error: expected ) before numeric constant dimensionedVector(dimLength, ( 0.1*max(mesh.C().component(0)) 0.5*max(mesh.C().component(1)) 0.) ) ^~~ createFields.H:369:2: error: expected ) before ; token ); ^ I'm using OF8. I'd be very grateful with any help. Greetings, Felipe |
coordinate, initial, length, openfoam, position |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 05:41 |
Pressure distribution on a wall | darazsbence | CFX | 17 | October 6, 2015 10:38 |
DPM cloud size and domain size dependency | MateuszK555 | FLUENT | 0 | April 19, 2015 16:50 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Size of rotating domain | Adam | CFX | 4 | November 28, 2006 10:28 |
