Home > Forums > Special Topics > Mesh Generation & Pre-Processing
STL connectivity
Old   November 12, 2020, 05:22
Default STL connectivity
kem
cfd
kem is on a distinguished road
I'm trying to find a way to check if two stl's are coincident (python preferred).
Let's say I have to parts, a cube with a central cutout in the shape of a triangular pyramid, and a triangular pyramid that fits into that cutout.
The correct parts should fit, but an incorrect part (say if you put a cube into the cutout) should be flagged.
So far I have found no ways of doing this.
Thanks for suggestions.
kem is offline   Reply With Quote
python script, stl file
[snappyHexMesh] What CAD software do you use to define STL surfaces? Awak OpenFOAM Meshing & Mesh Conversion 11 November 12, 2020 11:00
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[ICEM] STL file! How is it useful? bidi ANSYS Meshing & Geometry 0 December 26, 2016 21:33
mesh elements connectivity code from stl file Hyungyu Lee Mesh Generation & Pre-Processing 0 December 21, 2016 06:53
[snappyHexMesh] Experimentally obtained STL file for internal Flow SnappyHexMesh Irish09 OpenFOAM Meshing & Mesh Conversion 9 April 7, 2012 08:50
