Home > Forums > Special Topics > Mesh Generation & Pre-Processing
[Salome] Meshing Methodology in Salome for FSI
Old   July 14, 2023, 09:37
Lightbulb [Salome] Meshing Methodology in Salome for FSI
Tom
Tkon is on a distinguished road
Dear CFD community,
As part of my research, I am interested in applying fluid-structure interaction methodologies, specifically using the TurtleFSI solver, which is a monolithic FSI solver written in FEniCS. (https://github.com/KVSlab/turtleFSI) This solver requires a single mesh file that describes the subdomains for both the fluid and solid components.
I would like to adopt the meshing methodology presented in the following tutorial: https://www.youtube.com/watch?v=tmSnN3vgbNs. However, I would like to describe the fluid domain and vessel wall within a single mesh file, with tetrahedral elements for the fluid and solid. I have a couple of questions regarding the meshing process in Salome, particularly for complex geometries described by STL files without a clear definition of boundary surfaces (inlets, outlets, walls):
  1. When working with complex geometries represented by STL files, I am wondering if there is a convenient way in Salome to define patches, inlet/outlet surfaces, and walls. Since the STL file only provides facet information, I recall that in ICEM, one could segment surface zones based on angles. Is there a similar approach in Salome that someone could recommend?
  2. Additionally, I am curious to know how one would go about creating a vessel wall around a complex geometry using Salome.
    To your knowledge, is there a specific workflow or tool within Salome (or other software) that allows for the creation of a conformal vessel wall mesh, with additionally a definition of the outer-wall surface and side-wall surfaces?
    I found out about the "Modification-Extrusion-Extrusion by normal" tool, but this does not create a boundary surface for the sides of the vessel-wall.
Thank you in advance for taking the time to read and respond to my email. If you have any other suggestions for open-source tools to accomplish conformal meshing of a fluid/solid domain in complex geometries (defined in an STL file), please let me know.
Tkon is offline   Reply With Quote
fsi mesh, mesh 3d, salome forum
Salome meshing viscous layer thickness not reached BasJaka OpenFOAM Pre-Processing 0 May 11, 2023 03:25
Meshing methodology in ANSA for Star-CCM+ vinny.voona ANSA 1 January 5, 2022 04:24
Meshing methodology for star-ccm+ using ansa vinny.voona STAR-CCM+ 0 January 4, 2022 13:04
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
real shiphull meshing methodology Liang Main CFD Forum 0 December 27, 2001 04:22
