November 22, 2023, 06:50 |
Meshing of rectangular bubble column
Rep Power: 2 |
hi,
I am trying to mesh a rectangular 3D bubble column. With the aim to make a close to uniform hex mesh. Currently I make my geometry in DesignModeller and use Ansys meshing for mesh generation. However, I am running into problems due to the inlet, as it is only a small 2D rectangular portion of the bottom of the column. What I have tried so far to include the inlet distorts the mesh quite a lot. Do you have any suggestions on how to include the inlet to make a high-quality hex mesh? Or maybe I should try a different type of meshing? I also have access to ICEM and SpaceClaim if that helps. EDIT: Making the mesh using the blocking method in ICEM seemed to do the trick Last edited by SphericalCube; December 10, 2023 at 05:27. |
3dimensional, inlet, mesh, multiphase, rectangular |
CFD-Beginner: Bubble Column | BubbleQueen | STAR-CCM+ | 0 | July 1, 2023 14:17 |
Ansys fluent: Counter-flow bubble column by addition of secondary phase source term | AnthonyBowers | FLUENT | 0 | August 11, 2022 19:21 |
twoPhaseEulerFoam : bubble column modeling | chittipo | OpenFOAM Running, Solving & CFD | 2 | June 11, 2012 06:12 |
Modelling a Water-Air bubble column | GerhardHolzinger | OpenFOAM Running, Solving & CFD | 1 | February 28, 2012 04:12 |
Help required for CFD simulation of Trayed Bubble Column using Fluent | art705 | Main CFD Forum | 0 | July 15, 2009 04:04 |
