Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
particleTracks not working on reconstructed cases
Old   December 7, 2010, 10:41
Default particleTracks not working on reconstructed cases
lord_kossity's Avatar
Andreas Dietz
lord_kossity is on a distinguished road
When I try to post process a reconstructed lagrangian simulation with particleTracks I run into a segmentation fault.
The decomposition method was metis (but I also had similar problems with other decomposition methods).
Please see the outputs below for details:
user@workstation:~/OpenFOAM/OpenFOAM-1.6.x/tutorials/lagrangian/rhoPisoTwinParcelFoam/simplifiedSiwek> particleTracks
| \\ / O peration | Version: 1.6.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6.x-e913d57cbb98
Exec : particleTracks
Date : Dec 07 2010
Time :
Host : workstation
PID : 2474
Case : /home/user/OpenFOAM/OpenFOAM-1.6.x/tutorials/lagrangian/rhoPisoTwinParcelFoam/simplifiedSiwek
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Scanning times to determine track data for cloud thermoCloud1
Time = 0
Reading particle positions
--> FOAM Warning :
From function Cloud<ParticleType>::initCloud(const bool checkClass)
in file lnInclude/CloudIO.C at line 125
Cannot read particle positions file
"/home/user/OpenFOAM/OpenFOAM-1.6.x/tutorials/lagrangian/rhoPisoTwinParcelFoam/simplifiedSiwek/0/lagrangian/thermoCloud1"
assuming the initial cloud contains 0 particles.
Read 0 particles
Time = 0.01
Read 18 particles
Time = 0.02
Read 18 particles
Particle statistics:
Found 0 particles originating from processor 0
Generating 0 particle tracks for cloud thermoCloud1
Time = 0
--> FOAM Warning :
Constructing tracks
Time = 0.01
Constructing tracks
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/user/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/user/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 main in "/home/user/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/particleTracks"
#4 __libc_start_main in "/lib64/libc.so.6"
#5 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Segmentation fault
...and the associated particleTrackProperties
| \\ / O peration | Version: 1.6 |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object particleTrackProperties;
cloudName thermoCloud1;
sampleFrequency 1;
maxPositions 10000;
lord_kossity is offline   Reply With Quote
Old   February 22, 2013, 14:28
gmagoon is on a distinguished road
I was having a similar issue and figured out the problem just today. I'm not sure whether the same is a problem in your case, but I've just posted on what worked in my case: http://www.cfd-online.com/Forums/ope...tml#post409585
gmagoon is offline   Reply With Quote
Surface Tension Test Cases sega OpenFOAM Running, Solving & CFD 2 March 8, 2011 12:19
How to speed up the simulation of a large amount of similar steady state cases tss Main CFD Forum 4 November 5, 2010 14:36
Free OpenFOAM CHT Report and Cases (No Catch!) m.nichols19 OpenFOAM 6 August 23, 2010 21:40
CFD Validation Cases doug Main CFD Forum 4 January 11, 2010 19:28
Directory constructions of complex cases 7islands OpenFOAM 2 August 26, 2008 05:25
