July 23, 2013, 20:49 |
Implementation of dynOneEqEddy LES model
Hiroki Ono
Hi all,
I have doubts about implementation of incompressible::dynOneEqEddy turbulence model. For example, in the part of calculating ck, symmTensor MM is calculated as Code:
MM = simpleFilter_(-2.0*delta()*sqrt(KK)*filter_(D)) but I think, MM must be calculated as Code:
MM = delta()*(filter_(sqrt(k_)*D) - 2*sqrt(KK + filter_(k_))*filter_(D)) In addition, MM is calculated as the latter in "homogeneousDynOneEqEddy" Why the former is used? |
OpenFOAM: LES turbulence model names | Ollie | OpenFOAM | 5 | January 7, 2013 10:24 |
OpenFOAM: LES turbulence model names | Ollie | Main CFD Forum | 1 | April 11, 2011 13:03 |
help for different between les model (subgrid-scale model) | liuyuxuan | FLUENT | 1 | October 2, 2009 15:25 |
Regarding Implementation of Hershel Bulkley Model in Viscosity correlation | Pathak | FLOW-3D | 0 | August 24, 2009 06:34 |
2-equation model of LES and source code | M.R.Hadian | Main CFD Forum | 0 | February 3, 2002 05:00 |
