Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
wallGradU does not work in OF 2.2.2
Old   January 13, 2014, 12:28
Default wallGradU does not work in OF 2.2.2
Lee
SKLee is on a distinguished road
Hi All,
I run utility wallGradU for cases solving by rhoCentralFoam but it generates the gradient of velocity at the wall of zero. This is wrong answer.
Can someone check this ?
Sung-Ki
SKLee is offline   Reply With Quote
Old   February 10, 2014, 16:05
Retired Super Moderator
Bruno Santos
Greetings Sung-Ki,
I've taken a look into this and wallGradU works perfectly fine. The detail is that it's configured to only work on walls.
For example, if after the mesh is generated, you run this command:
patchSummary  -constant
You'll get a summary about the patches, e.g.:
wall    : top
    scalar        p        zeroGradient
    scalar        T        fixedValue
    vector        U        fixedValue
patch    : inlet
    scalar        p        fixedValue
    scalar        T        fixedValue
    vector        U        fixedValue
patch    : outlet
    scalar        T        zeroGradient
    vector        U        zeroGradient
symmetryPlane    : bottom
    scalar        p        symmetryPlane
    scalar        T        symmetryPlane
    vector        U        symmetryPlane
empty    : frontAndBack
    scalar        p        empty
    scalar        T        empty
    vector        U        empty
In this example, only the patch named "top" is of type wall, which means that wallGradU will only work for this patch.
In addition, when post-processing the case in ParaView, to visualize the "wallGradU" field, make sure you have loaded the patches of type "wall" in the "Mesh parts" section, as shown in the attached image.
Best regards,
Bruno
Old   February 12, 2014, 02:30
Lee
Thanks Bruno for your response. That's great.
I also have a problem with snGrad() function that I posted at
http://www.cfd-online.com/Forums/ope...heat-flux.html
I will be appreciated if you can help me to figure out it.
Sung-Ki
getting (0 0 0) wallGradU value when i m probing wallGradU at some points suryawanshi_nitin OpenFOAM 1 December 9, 2013 11:36
OpenFOAM 2.2.2 source pack installation on Xubuntu 13.10 zordiack OpenFOAM Installation 1 October 26, 2013 13:08
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 07:18
Why do the Plant library cases don't work? Alumna Phoenics 6 June 22, 2004 12:08
why my In-Form doesn't work? green Phoenics 2 May 27, 2004 21:03
