February 26, 2014, 17:56 |
using #calc in parallel with openFOAM 2.2.2
Pascal
Rep Power: 17 |
Hi all,
Does anyone had problem using using #calc in parallel with openFOAM 2.2.2? I use #calc to evaluate algebraic expressions in a file which is read by the controlDict and blockMeshDict. Everything seems to work just fine when I run with 1 processor but in parallel the simulation stop while evaluating some #calc expressions like that : Code:
ptX0 -4.00 ; ptX1 4.00 ; ptY0 0.00 ; ptY1 4.00 ; ptZ0 0.00 ; ptZ1 4.00 ; Nx 144 ; Ny 72 ; Nz 72 ; Lx #calc"$ptX1 - $ptX0"; Ly #calc"$ptY1 - $ptY0"; Lz #calc"$ptZ1 - $ptZ0"; dx #calc"$Lx/$Nx"; dy #calc"$Ly/$Ny"; dz #calc"$Lz/$Nz"; Code:
Lx 8; Ly 4; Lz 4; dx 0.0555555555555555; dy 0.0555555555555555; dz 0.0555555555555555; Code:
Lx #calc"8"; Ly #calc"4"; Lz #calc"4"; dx 0.0555555555555555; dy 0.0555555555555555; dz 0.0555555555555555; Anyone has notice such a behavior using #calc with OF 2.2.2? Thank you, Pascal |
March 19, 2014, 09:35 |
Jörn Nathan
Rep Power: 14 |
bump,
I am experiencing the same issue. The #calc directives work flawless when run on a single processor, but as soon, as they are called in a parallel run, the solver stucks without any activity or any messages. Is this a bug or misusage? Have a nice day, Jona |
March 23, 2014, 12:14 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Can any of you provide a simple test case, based on one of OpenFOAM's tutorials? It would make it faster and easier for someone else to diagnose this issue. Best regards, Bruno
March 25, 2014, 10:46 |
Jörn Nathan
Rep Power: 14 |
Of course. The example is the cavity from the tutorials but decomposed for two processors. So in order to run the case you need to
decomposePar mpirun -np 2 icoFoam -parallel When executing icoFoam, it stucks after the lines Using #calcEntry at line 30 in file ... Using #codeStream with ... Thanks a lot for your help, jona PS: The #calc entry is in the system/controlDict |
April 5, 2014, 19:58 |
Bruno Santos
Rep Power: 128 |
Hi jona,
I've finally managed to give a look into this. I've reproduced the issue and it seems to be a bug that has already been fixed in OpenFOAM 2.3.x, which was present in OpenFOAM 2.3.0. Mmm... I guess this was an issue back in OpenFOAM 2.2.2 as well... Now, if I could only figure out which commit fixed this issue... Found it, it's fixed in commit 8199b97e4a7ab5daa684abe27bdac2610cfb52a3: https://github.com/OpenFOAM/OpenFOAM...dac2610cfb52a3 Now, to apply this fix, it will depend on how you installed OpenFOAM. Best regards, Bruno
April 8, 2014, 12:44 |
Jörn Nathan
Rep Power: 14 |
Hello Bruno,
great, thanks a lot for looking into it and resolving the issue! Have a nice day, Jona |
Large test case for running OpenFoam in parallel | fhy | OpenFOAM Running, Solving & CFD | 23 | April 6, 2019 09:55 |
[mesh manipulation] Problem with RenumberMesh in parallel in OpenFOAM 2.1.1 | srini_esi | OpenFOAM Meshing & Mesh Conversion | 1 | November 8, 2013 02:48 |
OpenFOAM 2.2.2 source pack installation on Xubuntu 13.10 | zordiack | OpenFOAM Installation | 1 | October 26, 2013 13:08 |
OpenFOAM doesn't run in parallel | callumso | OpenFOAM Running, Solving & CFD | 0 | July 11, 2013 12:17 |
Parallel cluster solving with OpenFoam? P2P Cluster? | hornig | OpenFOAM Programming & Development | 8 | December 5, 2010 16:06 |
