September 14, 2011, 07:58 |
alphaEqn.H in twoPhaseEulerFoam
Charlie
Rep Power: 15 |
I had a chance to check what's going on in the alphaEqn.H in twoPhaseEulerFoam, and the basic idea is that they introduce a particle-particle stress to avoid higher volumetric concentration than alphaMax. and this artificial particle-particle stress does appear in the pEqn.H to modify the velocity field in particle phase directly. However, the author of this code try to modify phia in the alphaEqn.H, well I don't see it necessary because the velocity has already been modified in pEqn.H. Good thing is that, the rUaAf in alphaEqn.H is zero always ( you can print out the rUaAf value, and because you are calling rUaAf before it's defined in pEqn.H ) and thus ppMagf and phipp in alphaEqn.H is useless in alphaEqn.H, is that correct ? Any opinions are welcome, Thank you! Zhen |
September 15, 2011, 02:17 |
Alberto Passalacqua
Rep Power: 36 |
The code is correct: the idea behind the procedure is to directly include the effect of the particle pressure in the volume fraction equation. You probably noticed that the equation for alpha has an additional laplacian term which depends on ppMag.
If you include this term as done in the code, the flux must be subtracted of the contribution to the flux of the particle pressure computed at the previous time ste p. If you do not do this, you account for the same term twice (once using the old value, the second time due to the laplacian). Note that this becomes immediately clear if you perform the derivation: take the volume fraction equation, replace alpha*Ua with alpha_f*phia, as if you were deriving a pressure equation for the phase. Then extract the particle pressure term, and you will get exactly what is coded in OpenFOAM.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
September 15, 2011, 10:01 |
#3 | |
Charlie
Rep Power: 15 |
Hi, Aberto
Thanks for your reply! Yes, there is a ppMagf in laplacian term, but if you have a chance to see the value of this term, it's zero, always, even after the pEqn.H has been solved. So my argue is that this particle-particle stress does not appear in alphaEqn. Which I think is correct, ironically, since if you look at the pEqn, the velocity in particle phase has been modified already if you set g0>0. and I think the basic idea of this particle-particle idea is that through modification of Ua, we hope to constrain the alpha < alphaMax. Is that correct? Zhen Quote:
September 15, 2011, 11:06 |
Alberto Passalacqua
Rep Power: 36 |
In theory, the presence of the particle pressure gradient in the momentum equation should enforce the constraint alpha <= alphaMax. This is however a well known source of numerical instability in multi-fluid solvers, since the particle pressure term has a strongly non-linear dependency on the phase fraction.
In order to address this difficulty, you can include the effect of the particle pressure directly in the equation for the phase fraction. To do this, you proceed as I explained above, and you obtain exactly the form of the equation implemented in OpenFOAM. There is no reason for ppMagf or for the Laplacian term containing it to be zero everywhere if the phase fraction is high enough. Note that in the case of ppMagf, the term is zero for alpha < alphaMax, so the particle maximum packing will be higher than the specified one. However, the approach is general, and can be extended to the kinetic theory formulation. I have recently done this and other changes to the solver, and published a manuscript on the topic on Powder Technology, if you are interested. Best,
September 15, 2011, 21:14 |
#5 | |
Charlie
Rep Power: 15 |
Hi Alberto,
Thanks for your patient answer! I agree that there must a numerical trick in alphaEqn. however, let's derive step by step, and focus on where there is g0>0. first, in pEqn.H, there is a modification in phiDraga, which means that the particle-particle stress is implemented directly in the momentum equation.[CODE] if (g0.value() > 0.0) { phiDraga -= ppMagf*fvc::snGrad(alpha)*mesh.magSf(); } /CODE] after solving the pEqn.H, let's take a look at alphaEqn.H, the code modify the phir and phic again, from which we can see that it take into particle-particle stress on Ua twice ( once in pEqn, second here), in the code : [CODE] if (g0.value() > 0.0) { surfaceScalarField alphaf = fvc::interpolate(alpha); surfaceScalarField phipp = ppMagf*fvc::snGrad(alpha)*mesh.magSf(); phir += phipp; phic += fvc::interpolate(alpha)*phipp; } /CODE] then, in the alphaEqn, it eliminate the particle-particle stress once, which is in the laplacian term: Code:
if (g0.value() > 0.0) { ppMagf = rUaAf*fvc::interpolate ( (1.0/(rhoa*(alpha + scalar(0.00001)))) *g0*min(exp(preAlphaExp*(alpha - alphaMax)), expMax) ); alphaEqn -= fvm::laplacian ( (fvc::interpolate(alpha) + scalar(0.00001))*ppMagf, alpha, "laplacian(alphaPpMag,alpha)" ); } I've added a few lines in the code to print out the value of rUaAf in alphaEqn.H, and found that the value is uniformly 0, so I just want to clarify that, the original idea is to improve numerical stability, however, we found that the terms concerning ppMagf are zero indeed (I'm not to say that they should be zero, but it is zero as the way it was coded). Can you quickly add the line in the alphaEqn.H and print out the result of rUaAf? if I'm wrong, could you please let me know? Thank you! Many thanks! Zhen Quote:
September 15, 2011, 21:33 |
Alberto Passalacqua
Rep Power: 36 |
rUaAf is zero only at the first time-step, since rUaA is initialized to zero. If you look at pEqn.H, you have Code:
rUaAf = fvc::interpolate(rUaA); Code:
if (g0.value() > 0.0) { Info << "min(rUaAf) = " << min(rUaAf).value() << "max(rUaAf) = " << max(rUaAf).value() << endl; ppMagf = rUaAf*fvc::interpolate ( (1.0/(rhoa*(alpha + scalar(0.0001)))) *g0*min(exp(preAlphaExp*(alpha - alphaMax)), expMax) ); alphaEqn -= fvm::laplacian ( (fvc::interpolate(alpha) + scalar(0.0001))*ppMagf, alpha, "laplacian(alphaPpMag,alpha)" ); } Code:
Courant Number mean: 0.0450759 max: 0.0451754 Max Ur Courant Number = 0.0821135 deltaT = 0.00119048 Time = 0.10119 min(rUaAf) = 0max(rUaAf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.00552778, Final residual = 1.6595e-15, No Iterations 2 Dispersed phase volume fraction = 0.33099 Min(alpha) = 0 Max(alpha) = 0.410396 min(rUaAf) = 0max(rUaAf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.000331261, Final residual = 1.05713e-16, No Iterations 2 Dispersed phase volume fraction = 0.33099 Min(alpha) = 0 Max(alpha) = 0.410339 GAMG: Solving for p, Initial residual = 0.000659113, Final residual = 2.65448e-05, No Iterations 1 time step continuity errors : sum local = 2.53952e-06, global = 3.11192e-07, cumulative = 3.11192e-07 GAMG: Solving for p, Initial residual = 3.16091e-05, Final residual = 5.42006e-09, No Iterations 24 time step continuity errors : sum local = 5.93454e-07, global = 5.92783e-07, cumulative = 9.03975e-07 DILUPBiCG: Solving for epsilon, Initial residual = 0.0249787, Final residual = 6.68909e-08, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.0278856, Final residual = 1.44422e-07, No Iterations 2 ExecutionTime = 0.07 s ClockTime = 0 s Calculating averages Courant Number mean: 0.0536524 max: 0.0537346 Max Ur Courant Number = 0.0999525 deltaT = 0.00141156 Time = 0.102602 min(rUaAf) = 0.00117375max(rUaAf) = 0.00118477 DILUPBiCG: Solving for alpha, Initial residual = 0.00787966, Final residual = 1.03695e-14, No Iterations 2 Dispersed phase volume fraction = 0.331013 Min(alpha) = 0 Max(alpha) = 0.412684 min(rUaAf) = 0.00117375max(rUaAf) = 0.00118477 DILUPBiCG: Solving for alpha, Initial residual = 0.000974836, Final residual = 5.82784e-16, No Iterations 2 Dispersed phase volume fraction = 0.331013 Min(alpha) = 0 Max(alpha) = 0.412501 GAMG: Solving for p, Initial residual = 0.000288249, Final residual = 4.12155e-06, No Iterations 1 time step continuity errors : sum local = 1.20351e-06, global = 5.16087e-07, cumulative = 1.42006e-06 GAMG: Solving for p, Initial residual = 1.48219e-05, Final residual = 5.379e-09, No Iterations 23 time step continuity errors : sum local = 6.99062e-07, global = 6.9825e-07, cumulative = 2.11831e-06 DILUPBiCG: Solving for epsilon, Initial residual = 0.0263934, Final residual = 1.0387e-07, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.0284996, Final residual = 2.31919e-07, No Iterations 2 ExecutionTime = 0.11 s ClockTime = 0 s Calculating averages Courant Number mean: 0.0636171 max: 0.063778 Max Ur Courant Number = 0.118324 deltaT = 0.00167928 Time = 0.104281 min(rUaAf) = 0.00138437max(rUaAf) = 0.00140353 DILUPBiCG: Solving for alpha, Initial residual = 0.00809664, Final residual = 1.78739e-14, No Iterations 2 Dispersed phase volume fraction = 0.33104 Min(alpha) = 0 Max(alpha) = 0.414937 min(rUaAf) = 0.00138437max(rUaAf) = 0.00140353 DILUPBiCG: Solving for alpha, Initial residual = 0.00102087, Final residual = 1.24811e-15, No Iterations 2 Dispersed phase volume fraction = 0.33104 Min(alpha) = 0 Max(alpha) = 0.414745 GAMG: Solving for p, Initial residual = 0.00019334, Final residual = 6.26108e-06, No Iterations 1 time step continuity errors : sum local = 1.57192e-06, global = 5.63326e-07, cumulative = 2.68164e-06 GAMG: Solving for p, Initial residual = 1.70851e-05, Final residual = 6.02255e-09, No Iterations 23 time step continuity errors : sum local = 8.34896e-07, global = 8.33788e-07, cumulative = 3.51543e-06 DILUPBiCG: Solving for epsilon, Initial residual = 0.0304074, Final residual = 2.14845e-07, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.0331744, Final residual = 5.28396e-07, No Iterations 2 ExecutionTime = 0.16 s ClockTime = 0 s Calculating averages Courant Number mean: 0.0756831 max: 0.0758539 Max Ur Courant Number = 0.140544 deltaT = 0.00199414 Time = 0.106275 min(rUaAf) = 0.00164154max(rUaAf) = 0.00166791 DILUPBiCG: Solving for alpha, Initial residual = 0.00917989, Final residual = 2.60175e-14, No Iterations 2 Dispersed phase volume fraction = 0.331072 Min(alpha) = 0 Max(alpha) = 0.417257 min(rUaAf) = 0.00164154max(rUaAf) = 0.00166791 DILUPBiCG: Solving for alpha, Initial residual = 0.001015, Final residual = 2.1767e-15, No Iterations 2 Dispersed phase volume fraction = 0.331072 Min(alpha) = 0 Max(alpha) = 0.417063 GAMG: Solving for p, Initial residual = 0.000238078, Final residual = 9.40541e-06, No Iterations 1 time step continuity errors : sum local = 2.19634e-06, global = 5.81552e-07, cumulative = 4.09698e-06 GAMG: Solving for p, Initial residual = 2.04994e-05, Final residual = 7.48965e-09, No Iterations 23 time step continuity errors : sum local = 9.87082e-07, global = 9.85411e-07, cumulative = 5.08239e-06 DILUPBiCG: Solving for epsilon, Initial residual = 0.0347589, Final residual = 4.36944e-07, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.0383839, Final residual = 1.04614e-06, No Iterations 2 ExecutionTime = 0.2 s ClockTime = 0 s Best,
September 15, 2011, 21:48 |
#7 | |
Charlie
Rep Power: 15 |
Hi, Alberto,
Great!, thanks for your information, there must be something wrong with my coding. Thanks again, now my doubt has been removed, cheers! Best Zhen Quote:
September 15, 2011, 21:49 |
Alberto Passalacqua
Rep Power: 36 |
You are welcome :-)
September 15, 2011, 22:39 |
#9 |
Charlie
Rep Power: 15 |
Hi Alberto,
I'm sorry to bother again. actually, I did as you code in the alphaEqn, and compile using Allwmake, and the result is still like this: [HTML]Starting time loop Courant Number mean: 0.0110502 max: 0.05 Max Ur Courant Number = 0.05 Reading/calculating field UaMean Reading/calculating field UbMean Reading/calculating field alphaMean Reading/calculating field pMean fieldAverage: starting averaging at time 0 Time = 0.001 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 3.90098e-17, Final residual = 3.90098e-17, No Iterations 0 Dispersed phase volume fraction = 0.2015 Min(alpha) = 0 Max(alpha) = 0.62 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 3.90098e-17, Final residual = 3.90098e-17, No Iterations 0 Dispersed phase volume fraction = 0.2015 Min(alpha) = 0 Max(alpha) = 0.62 pressure gradient in UEqn= (0.081 0 0) kinTheory: max(Theta) = 1e-15 kinTheory: min(nua) = 5.06848e-07, max(nua) = 0.04 kinTheory: min(pa) = 0, max(pa) = 2.30439e-06 GAMG: Solving for p, Initial residual = 1, Final residual = 9.52665e-09, No Iterations 23 time step continuity errors : sum local = 2.15521e-12, global = -2.15521e-12, cumulative = -2.15521e-12 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.00104655, Final residual = 1.46481e-11, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = 0 Max(alpha) = 0.620052 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 4.06684e-05, Final residual = 8.19921e-12, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -1.64854e-21 Max(alpha) = 0.620052 GAMG: Solving for p, Initial residual = 0.0786421, Final residual = 9.35372e-09, No Iterations 17 time step continuity errors : sum local = 2.83579e-11, global = 2.83579e-11, cumulative = 2.62027e-11 DILUPBiCG: Solving for epsilon, Initial residual = 0.135913, Final residual = 2.09582e-06, No Iterations 4 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 1.43273e-06, No Iterations 5 pressure gradient = (0.081 0 0) ExecutionTime = 0.63 s ClockTime = 4 s Courant Number mean: 0.010322 max: 0.0500001 Max Ur Courant Number = 0.0343635 Calculating averages Time = 0.002 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.0010924, Final residual = 8.48925e-11, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -8.33627e-28 Max(alpha) = 0.620094 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 4.58883e-05, Final residual = 5.27276e-12, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -1.55414e-157 Max(alpha) = 0.620094 pressure gradient in UEqn= (0.081 0 0) kinTheory: max(Theta) = 58.918 kinTheory: min(nua) = 1.15627e-12, max(nua) = 0.04 kinTheory: min(pa) = -3.88536e-169, max(pa) = 2209.46 GAMG: Solving for p, Initial residual = 0.100408, Final residual = 8.11056e-09, No Iterations 15 time step continuity errors : sum local = 2.49503e-11, global = -2.49503e-11, cumulative = 1.25243e-12 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.000897803, Final residual = 1.59916e-12, No Iterations 4 Dispersed phase volume fraction = 0.2015 Min(alpha) = -1.45549e-14 Max(alpha) = 0.62193 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.000133328, Final residual = 1.37526e-11, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -1.26941e-26 Max(alpha) = 0.621929 GAMG: Solving for p, Initial residual = 0.034853, Final residual = 5.40877e-09, No Iterations 17 time step continuity errors : sum local = 2.02786e-11, global = 2.02786e-11, cumulative = 2.15311e-11 DILUPBiCG: Solving for epsilon, Initial residual = 0.0187545, Final residual = 8.89096e-07, No Iterations 3 DILUPBiCG: Solving for k, Initial residual = 0.800558, Final residual = 3.72508e-06, No Iterations 4 pressure gradient = (0.081 0 0) ExecutionTime = 0.93 s ClockTime = 5 s Courant Number mean: 0.010183 max: 0.0500034 Max Ur Courant Number = 0.0826851 Calculating averages Time = 0.003 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.00188765, Final residual = 1.59677e-12, No Iterations 4 Dispersed phase volume fraction = 0.2015 Min(alpha) = -6.81511e-22 Max(alpha) = 0.62233 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.000223479, Final residual = 1.52428e-11, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -7.91657e-26 Max(alpha) = 0.622328 pressure gradient in UEqn= (0.081 0 0) kinTheory: max(Theta) = 1000 kinTheory: min(nua) = 1.60279e-12, max(nua) = 0.04 kinTheory: min(pa) = -3.08412e-37, max(pa) = 2045.12 GAMG: Solving for p, Initial residual = 0.122225, Final residual = 7.73269e-09, No Iterations 17 time step continuity errors : sum local = 2.63962e-11, global = -2.63962e-11, cumulative = -4.8651e-12 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.000356051, Final residual = 2.09863e-11, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -4.54596e-16 Max(alpha) = 0.621036 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 8.30811e-05, Final residual = 7.85124e-13, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -1.08298e-25 Max(alpha) = 0.621036 GAMG: Solving for p, Initial residual = 0.016629, Final residual = 6.94633e-09, No Iterations 14 time step continuity errors : sum local = 2.18021e-11, global = 2.18021e-11, cumulative = 1.6937e-11 DILUPBiCG: Solving for epsilon, Initial residual = 0.020499, Final residual = 8.62327e-07, No Iterations 3 DILUPBiCG: Solving for k, Initial residual = 0.471488, Final residual = 2.08913e-06, No Iterations 4 pressure gradient = (0.081 0 0) ExecutionTime = 1.23 s ClockTime = 6 s Courant Number mean: 0.0101149 max: 0.0500028 Max Ur Courant Number = 0.126741 Calculating averages Time = 0.004 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.00167317, Final residual = 6.278e-11, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -6.07852e-25 Max(alpha) = 0.62135 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.000158778, Final residual = 3.213e-12, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -1.04731e-25 Max(alpha) = 0.621349 pressure gradient in UEqn= (0.081 0 0) kinTheory: max(Theta) = 1000 kinTheory: min(nua) = 1.60279e-12, max(nua) = 0.04 kinTheory: min(pa) = -7.28917e-21, max(pa) = 1950.06 GAMG: Solving for p, Initial residual = 0.0905112, Final residual = 9.85605e-09, No Iterations 15 time step continuity errors : sum local = 2.99527e-11, global = 2.99527e-11, cumulative = 4.68897e-11 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.000346857, Final residual = 3.04659e-12, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -3.26225e-16 Max(alpha) = 0.621475 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 7.42358e-05, Final residual = 1.26536e-12, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -2.41699e-25 Max(alpha) = 0.621475 GAMG: Solving for p, Initial residual = 0.0111199, Final residual = 9.2887e-09, No Iterations 12 time step continuity errors : sum local = 2.6559e-11, global = 2.6559e-11, cumulative = 7.34486e-11 DILUPBiCG: Solving for epsilon, Initial residual = 0.0216537, Final residual = 8.88015e-06, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.272703, Final residual = 7.4626e-06, No Iterations 3 pressure gradient = (0.081 0 0) ExecutionTime = 1.51 s ClockTime = 6 s Courant Number mean: 0.010065 max: 0.050003 Max Ur Courant Number = 0.145256 Calculating averages Time = 0.005 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.0014732, Final residual = 3.10609e-13, No Iterations 4 Dispersed phase volume fraction = 0.2015 Min(alpha) = -4.13607e-23 Max(alpha) = 0.621453 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.00013011, Final residual = 3.92767e-12, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -2.2714e-25 Max(alpha) = 0.621452 pressure gradient in UEqn= (0.081 0 0) kinTheory: max(Theta) = 1000 kinTheory: min(nua) = 1.60279e-12, max(nua) = 0.04 kinTheory: min(pa) = -1.4887e-21, max(pa) = 1860.09 GAMG: Solving for p, Initial residual = 0.0898181, Final residual = 9.60529e-09, No Iterations 16 time step continuity errors : sum local = 2.78988e-11, global = 2.78988e-11, cumulative = 1.01347e-10 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.000473163, Final residual = 2.11461e-11, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -3.87245e-18 Max(alpha) = 0.621414 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 6.93413e-05, Final residual = 3.96824e-12, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -3.91346e-26 Max(alpha) = 0.621414 GAMG: Solving for p, Initial residual = 0.0374737, Final residual = 9.59322e-09, No Iterations 13 time step continuity errors : sum local = 2.7584e-11, global = 2.75837e-11, cumulative = 1.28931e-10 DILUPBiCG: Solving for epsilon, Initial residual = 0.0222171, Final residual = 9.84455e-06, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.196096, Final residual = 4.79474e-06, No Iterations 3 pressure gradient = (0.081 0 0) ExecutionTime = 1.79 s ClockTime = 7 s Courant Number mean: 0.010023 max: 0.0500031 Max Ur Courant Number = 0.150859 Calculating averages Time = 0.006 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.00166162, Final residual = 2.33643e-11, No Iterations 4 Dispersed phase volume fraction = 0.2015 Min(alpha) = -3.90035e-25 Max(alpha) = 0.621333 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.000128721, Final residual = 5.15395e-12, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -1.56767e-25 Max(alpha) = 0.621334 pressure gradient in UEqn= (0.081 0 0) kinTheory: max(Theta) = 1000 kinTheory: min(nua) = 1.60279e-12, max(nua) = 0.04 kinTheory: min(pa) = -5.56552e-23, max(pa) = 1778.39 GAMG: Solving for p, Initial residual = 0.0744853, Final residual = 8.1907e-09, No Iterations 17 time step continuity errors : sum local = 2.52555e-11, global = 2.52555e-11, cumulative = 1.54187e-10 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.000528506, Final residual = 3.56838e-11, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -4.19315e-17 Max(alpha) = 0.621249 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 9.13973e-05, Final residual = 4.25874e-12, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -4.63227e-25 Max(alpha) = 0.621248 GAMG: Solving for p, Initial residual = 0.0460487, Final residual = 7.05426e-09, No Iterations 15 time step continuity errors : sum local = 2.20093e-11, global = 2.20093e-11, cumulative = 1.76196e-10 DILUPBiCG: Solving for epsilon, Initial residual = 0.0228629, Final residual = 9.47428e-06, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.155566, Final residual = 3.88173e-06, No Iterations 3 pressure gradient = (0.081 0 0) ExecutionTime = 2.1 s ClockTime = 8 s Courant Number mean: 0.00998571 max: 0.0500031 Max Ur Courant Number = 0.150683 Calculating averages Time = 0.007 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.00188168, Final residual = 7.31724e-12, No Iterations 4 Dispersed phase volume fraction = 0.2015 Min(alpha) = -1.087e-24 Max(alpha) = 0.62124 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.000164972, Final residual = 7.34103e-12, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -2.60664e-24 Max(alpha) = 0.621241 pressure gradient in UEqn= (0.081 0 0) kinTheory: max(Theta) = 1000 kinTheory: min(nua) = 1.60279e-12, max(nua) = 0.04 kinTheory: min(pa) = -2.89806e-19, max(pa) = 1716.94 GAMG: Solving for p, Initial residual = 0.0786497, Final residual = 8.33953e-09, No Iterations 16 time step continuity errors : sum local = 2.72705e-11, global = 2.72705e-11, cumulative = 2.03467e-10 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 0.000359687, Final residual = 2.1303e-11, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -7.1831e-18 Max(alpha) = 0.621369 max(rUaAf) = 0 min(rUaAf) = 0 max(ppMagf) = 0 min(ppMagf) = 0 DILUPBiCG: Solving for alpha, Initial residual = 6.24967e-05, Final residual = 2.79162e-12, No Iterations 3 Dispersed phase volume fraction = 0.2015 Min(alpha) = -6.99314e-28 Max(alpha) = 0.621369 GAMG: Solving for p, Initial residual = 0.0277413, Final residual = 6.64361e-09, No Iterations 14 time step continuity errors : sum local = 2.22131e-11, global = 2.22131e-11, cumulative = 2.2568e-10 DILUPBiCG: Solving for epsilon, Initial residual = 0.0237308, Final residual = 5.02822e-07, No Iterations 3 DILUPBiCG: Solving for k, Initial residual = 0.130643, Final residual = 3.80861e-06, No Iterations 3 pressure gradient = (0.081 0 0) ExecutionTime = 2.4 s ClockTime = 9 s Courant Number mean: 0.00995146 max: 0.050003 Max Ur Courant Number = 0.147262 Calculating averages/HTML] the code is like this: [CODE] if (g0.value() > 0.0) { Info<<"max(rUaAf) = "<<max(rUaAf).value()<<" min(rUaAf) = "<<min(rUaAf).value()<<endl; ppMagf = rUaAf*fvc::interpolate ( (1.0/(rhoa*(alpha + scalar(0.0001)))) *g0*min(exp(preAlphaExp*(alpha - alphaMax)), expMax) ); // Info<<"max(rUaAf) = "<<max(rUaAf).value()<<"min(rUaAf) = "<<min(rUaAf).value()<<endl; Info<<"max(ppMagf) = "<<max(ppMagf).value()<<" min(ppMagf) = "<<min(ppMagf).value()<<endl; alphaEqn -= fvm::laplacian ( (fvc::interpolate(alpha) + scalar(0.0001))*ppMagf, alpha, "laplacian(alphaPpMag,alpha)" ); } /CODE] so what I did wrong? do you have any idea? |
September 15, 2011, 22:45 |
#10 |
Alberto Passalacqua
Rep Power: 36 |
I use OpenFOAM 2.0.x, and tested on the tutorial for twoPhaseEulerFoam called "bed". Maybe you want to test on the same tutorial.
Best,
September 15, 2011, 23:55 |
#11 |
Charlie
Rep Power: 15 |
Hi Alberto,
Yeah, I'm using 1.7.1, maybe that's the reason. I'll try to implement 2.0, and see what's the difference. Thanks! Zhen |
September 17, 2011, 17:55 |
It turns out they added #include "pimpleControl.H"
#12 |
Charlie
Rep Power: 15 |
I've installed the openFOAM-2.0.1, and had a look at the twoPhaseEulerFoam, it turns out that they are using p.storePrevIter() to store the information obtained in pEqn, which has solved my concern. And solve the problem for OpenFOAM-1.7.1. Best Zhen |
September 18, 2011, 02:08 |
#13 | |
Alberto Passalacqua
Rep Power: 36 |
This has nothing to do with your former observation about rUaAf being zero. The twoPhaseEulerFoam in both 1.7.x and 2.0.x does not have rUaAf uniformly zero, since this would mean the reciprocal of the central coefficient rUaA (= 1/A) would be zero everywhere too, which is clearly not the case. Did you modify the code you were using in 1.7.x? Best, Alberto
September 18, 2011, 08:39 |
#14 | |
Charlie
Rep Power: 15 |
Yes, I've modified the code in 1.7.1 a little bit, but it's just in UEqns.H and twoPhaseEulerFoam.C, and I've tried to print out the rUaAf in pEqn.H. it's not zero, but in alphaEqn.H, it's zero, I've no idea what's going on. Did you try to see the value of rUaAf in alphaEqn.H in 1.7.1? Best Zhen Quote:
September 18, 2011, 13:46 |
#15 |
Alberto Passalacqua
Rep Power: 36 |
I switched some month ago to 2.0.x, however I did all my implementation in 1.7.x, and I do not meet the problem. Anyways, I would suggest to use 2.0.x, which has many improvements :-)
May 1, 2016, 16:12 |
#16 |
Rep Power: 14 |
Dear Charlie,
For twoPhaseEulerFoam, did you try any LES for particle laden flows, i.e. gas is the continuous phase and particle is the dispersed phase? Do you have any comments about running LES with twoPhaseEulerFOAM? Thanks. |
TwoPhaseEulerFOAM application | hemph | OpenFOAM Bugs | 35 | November 6, 2011 01:06 |
Something wrong in UEqns.H within twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM | 2 | June 24, 2011 10:48 |
twoPhaseEulerFoam | freemankofi | OpenFOAM | 0 | May 23, 2011 16:24 |
problems in Two Phase flow using twoPhaseEulerFoam with OpenFoam 1.6 | raagh77 | OpenFOAM Running, Solving & CFD | 0 | March 6, 2010 05:11 |
TwoPhaseEulerFOAM application | hemph | OpenFOAM Bugs | 0 | November 16, 2006 07:27 |
