fireFoam pyrolysisModel bug: phiGas is always zero (OF v1706) |
July 5, 2017, 09:05 |
In $FOAM_SRC/regionModels/pyrolysisModels/reactingOneDim/reactingOneDim.C, there is the following function:
void reactingOneDim::updateFields() { if (qrHSource_) { updateqr(); } //Note: Commented out as the sensible gas energy is included in energy eq. //updatePhiGas(); } As a consequence, for example in the combustion/fireFoam/LES/oppositeBurningPanels tutorial, there is no convective transport from the pyrolysis regions to region0. In this tutorial, the field 0/U contains: Code:
"(region0_to.*)" { type mappedFlowRate; nbrPhi phiGas; value uniform (0 0 0); } Which OpenFoam version is recommended to work with fireFoam? |
July 24, 2017, 19:33 |
Ashish Vinayak
Rep Power: 11 |
You need to uncomment updatePhiGas() since that is responsible for computing the gas release at the face.
If you don't want to use the enthalpy computation from updatePhiGas, you can comment that out instead within the function. |
How to setup a proper "heatFlux" boundary for fireFoam? | Jumping | OpenFOAM Pre-Processing | 0 | March 27, 2013 09:27 |
