chtMultiRegionSimpleFoam does not write converged time step |
October 9, 2017, 15:31 |
Tobias Holzmann
Rep Power: 51 |
Post from jaydeep (opened a new thread for that)...
Hi Tobi, A bit unrelated, but since you probably know the answer to this - in V5.0 chtMultiRegion seems not to write out converged timestep. I am using the same controlDict from tutorials Code:
application chtMultiRegionSimpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 25000; deltaT 1; writeControl adjustableRunTime; writeInterval 50; purgeWrite 1; writeFormat binary; writePrecision 10; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep yes; My feedback: Actually, you use a steady-state solver. The adjustRunTime should not do anything here. However, I did not get your point. Based on your controlDict, Foam should write out each 50th iteration and if you have the 100, it should remove the 50th one. It would be nice if you can tell us which controlDict it is. Based on adjustRunTime and adjustTimeStep it should not be a tutorial from the chtMu..:SIMPLEFoam solver. Or maybe I missed something? 2nd post: I realized I used controlDict from one of my other simulations... What I am observing is: Say my write control writes out 50, 100 .. Assume that convergence is obtained at 56, now the solver should write out 56. This happens in V4.1 but not V5.0. (all setup files remain the same)
Keep foaming, Tobias Holzmann |
October 9, 2017, 15:36 |
Tobias Holzmann
Rep Power: 51 |
Hey jaydeep,
I got your point. You meat the following. If one saves only each 1000 iteration but the solver converges after 143 iterations, this one should be saved definitely. I made a check and you are right, the OpenFOAM Dev version do not save the latest time step anymore. I will check it and make a patch for that. Thanks for reporting.
October 9, 2017, 15:41 |
Jaydeep
Rep Power: 10 |
Thanks!! Appreciate your quick response.
October 9, 2017, 15:44 |
Tobias Holzmann
Rep Power: 51 |
I wanted to change the convergence control that I build for 5.0 anyway because I want to have an output of the residual control at the beginning for the log files. If one have different settings, the log file will not show which residual controls were used. It could be, that my implemented residual control is the problem right now. Henry put it into the latest version, so maybe I did a bad job Give me one or two days. I will reply after I got the patch. Tobi
October 10, 2017, 17:45 |
Tobias Holzmann
Rep Power: 51 |
tomorrow I check my new implementation of the residual control for the log files. Seems to work fine but I have to make further tests. I will tell Henry to update the dev repo with the new files. However, I also fixed the problem with the converged time step. You can get the information here: https://bugs.openfoam.org/view.php?id=2720
October 13, 2017, 11:07 |
Tobias Holzmann
Rep Power: 51 |
Resolved in OpenFOAM-5.x by commit 65e6081e233698126ae8c5bf631c6df358c63b14
Resolved in OpenFOAM-dev by commit 50bedbb217fbc4c7a278838f53615e5136e0e5bd
October 14, 2017, 11:41 |
Jaydeep
Rep Power: 10 |
Thanks Tobi. I saw the update on Issue Tracking.
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
