Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Suggestion for new description in documentation of waveTransmissive BC
Old   August 23, 2022, 11:03
Default Suggestion for new description in documentation of waveTransmissive BC
Julio Pieri
JulioPieri is on a distinguished road
Hi all,
I have a suggestion to make.
In the waveTransmission BC documentation, "gamma" is defined as "ratio of specific heats". However, this leads to a lot of confusion (as I seen around) when we are dealing with liquids.
I believe the correct description would be something like "numerator of the wave speed formula", which ends up being 1 for water.
From the .C file:
    // Calculate the speed of the field wave w
    // by summing the component of the velocity normal to the boundary
    // and the speed of sound (sqrt(gamma_/psi)).
For liquid, the OF's \psi is 1/(B/rho), where B is the bulk modulus of the liquid. This is the reciprocal of (the square of) the wave speed! So that formula ends up taking gamma as 1 (at least for weak compressible water).
A simple change that can help some users in the future!
JulioPieri is offline   Reply With Quote
Trouble with PyFoamPrepareCase.py LCammiade OpenFOAM Pre-Processing 0 June 24, 2019 08:59
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
