OPENFOAM v10 - Cannot find functionObject configuration file flowRatePatch |
Leonardo Lemos
Rep Power: 0 ![]() |
Hello!
I was trying to create a polymesh from a Mesh_3d.unv file and I received the message below: ❯ ideasUnvToFoam Mesh_3d.unv /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 10-c4cf895ad8fa Exec : ideasUnvToFoam Mesh_3d.unv Date : Mar 06 2023 Time : 21:27:32 Host : ---- PID : 26205 I/O : uncollated Case : $/run/venturi3d nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: Cannot find functionObject configuration file flowRatePatch Available configured functionObjects: 89 ( CourantNo Lambda2 MachNo PecletNo Q Qdot XiReactionRate add age boundaryProbes cellMax cellMaxMag cellMin cellMinMag components cutPlaneSurface ddt div divide dsmcFields enstrophy faceZoneAverage faceZoneFlowRate fieldAverage flowType forceCoeffsCompressible forceCoeffsIncompressible forcesCompressible forcesIncompressible grad graphCell graphCellFace graphFace graphLayerAverage graphUniform interfaceHeight internalProbes isoSurface log mag magSqr multiply particles patchAverage patchDifference patchFlowRate patchIntegrate patchSurface phaseForces phaseMap phaseScalarTransport populationBalanceMoments populationBalanceSizeDistribution probes randomise reconstruct residuals scalarTransport scale shearStress staticPressureIncompressible stopAtClockTime stopAtFile streamFunction streamlinesLine streamlinesPatch streamlinesPoints streamlinesSphere subtract surfaceInterpolate time timeStep totalEnthalpy totalPressureCompressible totalPressureIncompressible triSurfaceDifference triSurfaceVolumetricFlowRate turbulenceFields turbulenceIntensity uniform vorticity wallHeatFlux wallHeatTransferCoeff wallShearStress writeCellCentres writeCellVolumes writeObjects writeVTK yPlus ) file:$/run/venturi3d/system/controlDict/functions From function static bool Foam::functionObjectList::readFunctionObject(const Foam::string&, Foam::dictionary&, const Foam::Pair<Foam::string>&, const Foam::word&) in file db/functionObjects/functionObjectList/functionObjectList.C at line 250. FOAM exiting Have anyone seen this error? Thanks in advance. |
Display Modes | |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
