jinhoon park
Rep Power: 3 ![]() |
I am trying to implement blockMesh through blockMeshDict.
But I keep getting this error. I have no idea what the reason is.... please help me!!! --> FOAM FATAL ERROR: The parent directory does not allow write permission to the process, or one of the directories in "/home/hearim/OpenFOAM/hearim-10/run/test/constant/polyMesh" did not allow search (execute) permission. From function bool Foam::mkDir(const Foam::fileName&, mode_t) in file POSIX.C at line 346. FOAM exiting |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
