"Seeking Help to Resolve OpenFOAM Error: Inflow Velocity Point Not Found in Mesh" |
Haider
Rep Power: 3 ![]() |
Hello OpenFOAMERS,
Can anyone guide me on how to fix the following error? I tried both serial and decomposition methods (e.g. scotch, hierarchical) but the problem is not resolving, looking forward to suggestions. Thank You! Regards, Haider [8] --> FOAM FATAL ERROR: (openfoam-2012) [8] Inflow velocity point for turbine.blade3.element16 not found in mesh [8] [8] From void actuatorLineElement::calculateForce() [8] in file fvOptions/actuatorLineSource/actuatorLineElement/actuatorLineElement.C at line 468. [8] FOAM parallel run aborting |
[OpenFOAM.org] Not found many .so files when installing OpenFOAM 6 | lengjun | OpenFOAM Installation | 2 | December 12, 2022 22:08 |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
[Other] Compiling hacFoam (Ubuntu 10.04)(OF2.0.0)(LAMMPS13Jul2010)) | Henrik_E | OpenFOAM Installation | 3 | September 29, 2016 16:16 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
