Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Compiling New Reynolds Stress Models
Old   February 13, 2024, 05:32
Default Compiling New Reynolds Stress Models
ASR
sr786 is on a distinguished road
I have been attempting to compile a new turbulence model for the RSM LRR and SSG in OpenFOAM-9 where I am using LINUX OpenSUSE-v15.4.
Prior to modifying the code I am first testing if I can successfully compile a new turbulence model. I first tried out compiling kEpsilon & kOmega which worked fine.
mykEpsilon:
wmake libso .
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file mykinematicMomentumTransportModels.C
g++ -std=c++14 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/momentumTransportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/incompressible/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/transportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/finiteVolume/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/meshTools/lnInclude  -IlnInclude -I. -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OSspecific/POSIX/lnInclude   -fPIC -c mykinematicMomentumTransportModels.C -o Make/linux64GccDPInt32Opt/mykinematicMomentumTransportModels.o
g++ -std=c++14 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/momentumTransportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/incompressible/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/transportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/finiteVolume/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/meshTools/lnInclude  -IlnInclude -I. -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OSspecific/POSIX/lnInclude   -fPIC -fuse-ld=bfd -shared -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/mykinematicMomentumTransportModels.o -L/home/cfd/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/lib \
    -ltransportModels -lmomentumTransportModels -lfiniteVolume -lmeshTools  -o /home/cfd/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/lib/mykinematicMomentumTransportModels.so
mykOmega
 wmake libso .
The issue appears when I try compiling the RSM, using same strategy as before. There appears to be error messages leading to a failure in compilation:
simpleSSG
 wmake libso .
In file included from simpleSSG.H:210:0,
                 from mykinematicMomentumTransportModels.C:47:
simpleSSG.C: In instantiation of ‘Foam::RASModels::simpleSSG<BasicMomentumTransportModel>::simpleSSG(const alphaField&, const rhoField&, const volVectorField&, const surfaceScalarField&, const surfaceScalarField&, const transportModel&, const Foam::word&) [with BasicMomentumTransportModel = Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel>; Foam::RASModels::simpleSSG<BasicMomentumTransportModel>::alphaField = Foam::geometricOneField; Foam::RASModels::simpleSSG<BasicMomentumTransportModel>::rhoField = Foam::geometricOneField; Foam::volVectorField = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>; Foam::RASModels::simpleSSG<BasicMomentumTransportModel>::transportModel = Foam::kinematicTransportModel]’:
/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/momentumTransportModels/lnInclude/RASModel.H:100:9:   required from ‘static Foam::autoPtr<Foam::RASModel<BasicMomentumTransportModel> > Foam::RASModel<BasicMomentumTransportModel>::adddictionaryConstructorToTable<RASModelType>::New(const alphaField&, const rhoField&, const volVectorField&, const surfaceScalarField&, const surfaceScalarField&, const transportModel&) [with RASModelType = Foam::RASModels::simpleSSG<Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel> >; BasicMomentumTransportModel = Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel>; Foam::RASModel<BasicMomentumTransportModel>::alphaField = Foam::geometricOneField; Foam::RASModel<BasicMomentumTransportModel>::rhoField = Foam::geometricOneField; Foam::volVectorField = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>; Foam::RASModel<BasicMomentumTransportModel>::transportModel = Foam::kinematicTransportModel]’
/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/momentumTransportModels/lnInclude/RASModel.H:100:9:   required from ‘Foam::RASModel<BasicMomentumTransportModel>::adddictionaryConstructorToTable<RASModelType>::adddictionaryConstructorToTable(const Foam::word&) [with RASModelType = Foam::RASModels::simpleSSG<Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel> >; BasicMomentumTransportModel = Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel>]’
mykinematicMomentumTransportModels.C:48:1:   required from here
simpleSSG.C:228:14: error: ‘bound’ was not declared in this scope
         bound(epsilon_, this->epsilonMin_);
simpleSSG.C:228:14: note: suggested alternative: ‘found’
         found
simpleSSG.C: In instantiation of ‘void Foam::RASModels::simpleSSG<BasicMomentumTransportModel>::correct() [with BasicMomentumTransportModel = Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel>]’:
mykinematicMomentumTransportModels.C:48:24:   required from here
simpleSSG.C:335:10: error: ‘bound’ was not declared in this scope
simpleSSG.C:335:10: note: suggested alternative: ‘found’
     found
make: *** [/home/cfd/OpenFOAM/OpenFOAM-9/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/mykinematicMomentumTransportModels.o] Error 1
simpleLRR
 wmake libso .
In file included from simpleLRR.H:219:0,
simpleLRR.C: In instantiation of ‘Foam::RASModels::simpleLRR<BasicMomentumTransportModel>::simpleLRR(const alphaField&, const rhoField&, const volVectorField&, const surfaceScalarField&, const surfaceScalarField&, const transportModel&, const Foam::word&) [with BasicMomentumTransportModel = Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel>; Foam::RASModels::simpleLRR<BasicMomentumTransportModel>::alphaField = Foam::geometricOneField; Foam::RASModels::simpleLRR<BasicMomentumTransportModel>::rhoField = Foam::geometricOneField; Foam::volVectorField = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>; Foam::RASModels::simpleLRR<BasicMomentumTransportModel>::transportModel = Foam::kinematicTransportModel]’:
/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/momentumTransportModels/lnInclude/RASModel.H:100:9:   required from ‘static Foam::autoPtr<Foam::RASModel<BasicMomentumTransportModel> > Foam::RASModel<BasicMomentumTransportModel>::adddictionaryConstructorToTable<RASModelType>::New(const alphaField&, const rhoField&, const volVectorField&, const surfaceScalarField&, const surfaceScalarField&, const transportModel&) [with RASModelType = Foam::RASModels::simpleLRR<Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel> >; BasicMomentumTransportModel = Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel>; Foam::RASModel<BasicMomentumTransportModel>::alphaField = Foam::geometricOneField; Foam::RASModel<BasicMomentumTransportModel>::rhoField = Foam::geometricOneField; Foam::volVectorField = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>; Foam::RASModel<BasicMomentumTransportModel>::transportModel = Foam::kinematicTransportModel]’
/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/momentumTransportModels/lnInclude/RASModel.H:100:9:   required from ‘Foam::RASModel<BasicMomentumTransportModel>::adddictionaryConstructorToTable<RASModelType>::adddictionaryConstructorToTable(const Foam::word&) [with RASModelType = Foam::RASModels::simpleLRR<Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel> >; BasicMomentumTransportModel = Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel>]’
simpleLRR.C:219:14: error: ‘bound’ was not declared in this scope
simpleLRR.C:219:14: note: suggested alternative: ‘found’
         found
simpleLRR.C: In instantiation of ‘void Foam::RASModels::simpleLRR<BasicMomentumTransportModel>::correct() [with BasicMomentumTransportModel = Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel>]’:
simpleLRR.C:325:10: error: ‘bound’ was not declared in this scope
simpleLRR.C:325:10: note: suggested alternative: ‘found’
     found
sr786 is offline   Reply With Quote
Old   March 7, 2024, 09:11
Agustín Villa
agustinvo is on a distinguished road
Hi
Have you checked if you are adding the bound.H in your header?
agustinvo is offline   Reply With Quote
Reynold's Stress not shown anjansir OpenFOAM Post-Processing 0 December 16, 2011 01:55
Reynolds Stress Boundary Conditions tstorm FLUENT 0 July 27, 2009 14:44
Questions about the Reynolds stress model empirer2002 Main CFD Forum 1 January 5, 2006 07:37
Reynolds Stress Models amelia OpenFOAM Running, Solving & CFD 1 August 11, 2005 17:12
reynolds stress tufito Main CFD Forum 3 March 10, 2005 15:40
