Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Compressible kOmegaSST
Like Tree35Likes
Old   August 30, 2007, 06:04
Default Hi, I'm not really sure it i
cosimo bianchini
cosimobianchini is on a distinguished road
Send a message via Skype™ to cosimobianchini
I'm not really sure it is a bug (I'm still working with version 1.3 and so I didn't try it) but it seems to me that the new (1.4.1 release) compressible kOmegaSSTomega has wrong production terms for both omega and k equations (also dimensionally):
/* this is the relevant part of the code
volScalarField GbyMu = 2*mut_*(tgradU() && dev(symm(tgradU())));
volScalarField G = mut_*GbyMu;
tmp<fvscalarmatrix> omegaEqn
fvm::ddt(rho_, omega_)
+ fvm::div(phi_, omega_)
- fvm::laplacian(DomegaEff(F1), omega_)
rhoGammaF1*GbyMu
- fvm::SuSp((2.0/3.0)*rhoGammaF1*divU, omega_)
- fvm::Sp(rho_*beta(F1)*omega_, omega_)
- fvm::SuSp
rho_*(F1 - scalar(1))*CDkOmega/omega_,
omega_
tmp<fvscalarmatrix> kEqn
fvm::ddt(rho_, k_)
+ fvm::div(phi_, k_)
- fvm::laplacian(DkEff(F1), k_)
min(G, c1*betaStar*k_*omega_)
- fvm::SuSp(2.0/3.0*rho_*divU, k_)
- fvm::Sp(rho_*betaStar*omega_, k_)
I guess that it should instead be something like:
volScalarField G_DividedbyMu = 2*(tgradU() && dev(symm(tgradU())));
volScalarField G = mut_*G_DividedbyMu;
rhoGammaF1*G_DividedbyMu
- fvm::SuSp
omega_
fvm::ddt(rho_, k_)
Can you please tell me if someone agrees with me?
Regards
Cosimo
Cosimo Bianchini
Ergon Research s.r.l.
Via Panciatichi, 92
50127 Florence - ITALY
Tel: +39 055 0763716
Mob: +39 320 9460153
e-mail: cosimo.bianchini@ergonresearch.it
URL: www.ergonresearch.it
cosimobianchini is offline   Reply With Quote
Old   August 30, 2007, 06:17
Default Yes your are correct, I implem
henry is on a distinguished road
Yes your are correct, I implemented the model just before release and didn't have time to test it. I will check it through again, test it and post a corrected version next week sometime.
henry is offline   Reply With Quote
Old   August 31, 2007, 10:18
Default Here is a corrected version of
Here is a corrected version of kOmegaSST.C
kOmegaSST.C
to replace the file in OpenFOAM-1.4.1/src/turbulenceModels/compressible/kOmegaSST
I have tested the model runs and give sensible results but I have not performed a rigorous validation.
Ramzy1990 likes this.
Old   September 24, 2007, 06:39
Default Hi Henry, just another small
cosimo bianchini
Hi Henry,
just another small doubt about the limiter for mut.
I could not download the paper you suggest as reference for this model but the reference paper I used for implementing the kOmegaSST (Heat Transfer Predictions using Advanced Two-Equation Turbulence Models; Wolfgang Vieser, Thomas Esch and Florian Menter; CFX Technical Memorandum: CFX-VAL10/0602, 2002) have a different limiter for mut:
mut = rho* a1*k/max(a1*omega,sqrt(2)*mag(symm(gradU)*F2));
The standard release instead is using:
mut = rho* a1*k/max(a1*omega,mag(symm(gradU)*F2));
Is it a bug or it is just a correction to make it suitable for heat transfer applications?
Please tell me what is your paper saying about that.
Thanks a lot
Cosimo
Cosimo Bianchini
Via Panciatichi, 92
Old   September 24, 2007, 06:51
Default All the k-Omega papers I have
All the k-Omega papers I have give this term without the sqrt(2) but then it could easily be contained in a1. What value is proposed for a1 in CFX-VAL10/0602 and does it differ from the value proposed in the papers on the model?
Old   September 24, 2007, 07:50
Default I defintely agree with you.
cosimo bianchini
My value for a1 is 0.31 so if the two equations are consistent your should be 0.31/sqrt(2) = 0.2192.
Thanks for confirming that.
Cosimo
Cosimo Bianchini
Via Panciatichi, 92
Old   September 24, 2007, 07:52
Default Hi, I am testing the kOmega
Claus H. Ibsen
chibsen is on a distinguished road
I am testing the kOmegaSST model using the above kOmegaSST.C file.
I am getting this error messages:
--> FOAM FATAL ERROR : incompatible dimensions for operation
[omega[1 -3 -2 0 0 0 0] ] - [((rho*((tanh(pow4(min(min(max((((1|betaStar)*sqrt( k))|(omega*y)),((500*(mu|rho) )|(sqr(y)*omega))),(((4*alphaOmega2)*k)|(max((((2* alphaOmega2)*(grad(k)&grad(ome ga)))|omega),1.0e-10)*sqr(y)))),10)))*(gamma1-gamma2))+gamma2))*((2*mut)*(grad(U )&&dev(symm(grad(U))))))[2 -4 -3 0 0 0 0] ]#0 Foam::error::printStack(Foam:stream&) in "/home/ci/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/ci/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 void Foam::checkMethod<double>(Foam::fvMatrix<double> const&, Foam::GeometricField<double,> const&, char const*) in "/home/ci/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/rhoSimpleFoam"
#3 Foam::tmp<foam::fvmatrix<double> > Foam::operator-<double>(Foam::tmp<foam::geometricfield<double,> > const&, Foam::tmp<foam::fvmatrix<double> > const&) in "/home/ci/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libcompressibleTurbulenceMod els.so"
#4 Foam::compressible::turbulenceModels::kOmegaSST::c orrect() in "/home/ci/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libcompressibleTurbulenceMod els.so"
#5 main in "/home/ci/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/rhoSimpleFoam"
#6 __libc_start_main in "/lib/libc.so.6"
#7 Foam::regIOobject::readIfModified() in "/home/ci/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/rhoSimpleFoam"
From function checkMethod(const fvMatrix<type>&, const GeometricField<type,>&)
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/fvMatrix.C at line 1232.
FOAM aborting
Is that an error in my setup of the case, or is the error in the kOmegaSST.C file?
Thanks,
Claus.
chibsen is offline   Reply With Quote
Old   September 24, 2007, 08:56
Default The value of a1 in the papers
The value of a1 in the papers I have is also 0.31. I don't know at what point Menter added the sqrt(2) prefactor I haven't seen it in any of the published papers on the k-Omega model I have but I don't have a full set.
Old   September 24, 2007, 11:16
Default Hi Claus! I would guess tha
Assistant Moderator
Bernhard Gschaider
Hi Claus!
I would guess that the problem is with the setup. One common problem is that people take a k-eps-case, rename the epsilon-file to omega but don't change the dimensions (although that would not explain the difference in dimensions in your case). Check the dimensions
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 24, 2007, 11:54
Default Hi Weller, I also have got a
cosimo bianchini
Hi Weller,
I also have got an article without the sqrt(2):
Menter, Two Equation Eddy-Viscosity Turbulence Models for Engineering Applications, AIAA Journal Vol.32 , N 8, 1994.
In that case however:
mut = rho* a1*k/max(a1*omega,mag(OMEGA)*F2));
with OMEGA = absolute value of vorticity = mag(curl(U)) != strain rate magnitude = 0.5*(grad(U) + grad(U).T).
Could this be the mistake? Am I misunderstanding anything?
Regards
Cosimo
Cosimo Bianchini
Via Panciatichi, 92
Old   September 24, 2007, 12:03
Default It is not a mistake, the model
  #11
It is not a mistake, the model has evolved over the years particularly in this term. I assure your that what I have implemented is what is in the paper I refer to in the header. I cannot say if the form you are referring to is preferable to the form I have implemented as I do not have all the relevant literature on the subject.
Old   September 24, 2007, 12:44
Default You are right: there are sever
  #12
cosimo bianchini
You are right: there are several different versions of such model. I do not have all the papers as well but, as far as I can see, your version is actually the same model implemented in CFX 10.
Thanks for this clarification,
Cosimo
Cosimo Bianchini
Via Panciatichi, 92
Old   September 25, 2007, 05:48
Default I forgot to wmake... everythin
  #13
Claus H. Ibsen
I forgot to wmake... everything is working nice now.
Sorry for the inconvenience.
Claus.
Old   January 21, 2009, 09:55
Default Could somebody please supply m
  #14
Andrew Parker
a-jp is on a distinguished road
Could somebody please supply me with an electronic copy of: Heat Transfer Predictions using Advanced Two-Equation Turbulence Models; Wolfgang Vieser, Thomas Esch and Florian Menter; CFX Technical Memorandum: CFX-VAL10/0602, 2002
I understand this explains the automatic wall function treatment for the SST model, I would appreciate any papers which discuss this, not just the above. The only reference I can find is in Menter's Ten years of industrial experiance with the SST model, ref [8], but I can't seem to find the paper anywhere??
Any help would be appreciated.
Cheers,
Andy
a-jp is offline   Reply With Quote
Old   November 13, 2009, 23:59
Mahwish
msohail is on a distinguished road
I have the same problem .I want to know how SSt handels low Re number flows
msohail is offline   Reply With Quote
Old   November 14, 2009, 05:19
The k-omega-SST model I implemented is the high-Re form to be used with the standard, continuous/adaptive or rough wall-functions supplied. However it would be quite easy to implement the low-Re form of the model as this simply requires the application of damping functions on a few terms.
H
Old   November 14, 2009, 13:23
Fabian Braennstroem
braennstroem is on a distinguished road
As I understood it, the current implemented SST model is suitable for low-re flows as well. Though one needs different wall treatment (especially for omega). And maybe the use of some damping functions is better. Do you have any experience in it?
Fabian
braennstroem is offline   Reply With Quote
Old   November 14, 2009, 14:25
The k-omega-SST model we currently release is based on a blend of the high-Re k-epsilon and k-omega models, not the low Re k-omega model. With an adaptive/continuous wall-function you can use this model to resolve the near-wall low-Re flow with some degree of accuracy but if you want to resolve these details accurately you will need to include the low-Re damping-functions into the k-omega part of the model and use a mesh with adequate resolution in the near-wall region.
H
fumiya and stingph like this.
Old   November 14, 2009, 14:44
Fabian Braennstroem
Thanks for the explanation!
Fabian
Old   November 15, 2009, 17:12
Mahwish
Thanks a lot .
But by solving right to the wall will be espensive right that's why we avoid that .Rather than using wall functions will be a cheap alternative. I don't know what CFX using as a standard SST model .
Nearwall treatment for the kOmegaSST turbulence model johnb OpenFOAM Running, Solving & CFD 3 January 22, 2009 02:52
ChtMultiRegionFoam kOmegaSST solidDisplacementFoam marico OpenFOAM Running, Solving & CFD 4 January 16, 2009 02:51
How can run MRFSimpleFoam with KOmegaSST turbulence model waynezw0618 OpenFOAM Running, Solving & CFD 0 April 21, 2008 04:40
Question on new implemented komegaSST model in OF 14 peterh OpenFOAM Running, Solving & CFD 7 February 7, 2008 02:09
compressible John Main CFD Forum 1 April 6, 2003 12:35
