Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Bug in reconstructPar
Old   January 9, 2009, 07:14
Default Hi everybody I found a bug
David Hora
david is on a distinguished road
Hi everybody
I found a bug in the reconstruction of decomposed cases with moving (not deforming) meshes. The new positions of the mesh points are reconstructed correctly if reconstructPar is used without any optional parameters. When the parameters -time or -latestTime are used, the points are not being reconstructed. The problem occurs with OpenFOAM-1.4.1 and 1.5.
Regards
David
see also:
http://www.cfd-online.com/OpenFOAM_D...es/1/9644.html
david is offline   Reply With Quote
Old   January 12, 2009, 06:40
Default Thanks. Attached a fix. Could
Mattijs Janssens
mattijs is on a distinguished road
Thanks. Attached a fix. Could you let us know whether it works in general and I'll push it into 1.5.x.
reconstructPar.C
mattijs is offline   Reply With Quote
Old   January 12, 2009, 10:52
Default Hi Mattijs The fix is worki
David Hora
Hi Mattijs
The fix is working. Thanks a lot.
Regards
David
Old   April 22, 2009, 04:51
Andreas Feymark
feymark is on a distinguished road
Hi everyone!
I'm having problem using reconstructPar -latestTime on a moving mesh. The problem is that the polyMesh-directory is not reconstructed. reconstructPar -time TIME works aslong as I don't use the latest time as TIME. I have tried the latest version of reconstructPar from the svn and also the code Mattijs posted here, it did not work.
Regards,
Feymark
feymark is offline   Reply With Quote
Old   April 23, 2009, 13:35
Mattijs Janssens
Hi Feymark,
I've pushed a change to 1.5.x which worked on my testcase. Could you let me know if there are any problems with it?
Thanks,
Mattijs
Old   April 27, 2009, 07:33
Andreas Feymark
It works, thanks a lot!
/Feymark
Old   April 27, 2009, 09:50
Andreas Feymark
I have another problem regarding but decomposePar this time. When I try to run decomposePar the polyMesh-dir isn't decomposed.
Best regards,
Feymark
Old   April 27, 2009, 10:02
Andreas Feymark
I should add that I have, before doing reconstructPar and removing the processor*-folders, 2 different polyMesh-folders under each processor*/-folder. After performing decomposePar the polyMesh in processor*/constant/ is there but not the one in processor*/TIME.
Regards,
Feymark
Old   April 28, 2009, 04:44
Mattijs Janssens
Does it work with -time? (so directly point at the time-with-polyMesh)
Old   April 28, 2009, 05:50
Andreas Feymark
reconstructPar works perfectly fine now. This is a problem with decomposePar and -time is not a valid option there. The polyMesh-folder that is suppose to be in the processor*/TIME-folder is not there after decomposing, only the polyMesh in processor*/constant.
/Feymark
Old   May 26, 2009, 12:11
Mattijs Janssens
Hi Feymark,
I pushed a few small changes into 1.5.x which should fix the problem for decomposing cases with meshes in time directories. If the original mesh (at the specified time) originates from anything other than 'constant' it will write the mesh to the time directory. E.g. original case has
- full mesh in constant
- polyMesh/points in 0.3
and current time is 0.5 it will create a full mesh in processor*/0.5/polyMesh and not create a constant folder.
Thanks for reporting.
ReconstructPar kupiainen OpenFOAM Post-Processing 12 April 21, 2009 01:47
[mesh manipulation] Error with reconstructPar skabilan OpenFOAM Meshing & Mesh Conversion 3 June 10, 2008 18:34
ReconstructPar maka OpenFOAM Bugs 6 August 22, 2007 04:23
Problem with reconstructPar fabianpk OpenFOAM 5 August 14, 2007 09:17
ReconstructPar error r2d2 OpenFOAM Pre-Processing 7 September 12, 2006 09:37
