Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
SnappyHexMesh and planar STL surfaces
Old   August 1, 2008, 08:23
Default Description: When planar STL
Hannes Kröger
hannes is on a distinguished road
Description:
When planar STL surfaces which are aligned with coordinate planes are supplied to snappyHexMesh, an error message like to following occurs:
Edge intersection testing:
Number of edges : 74800
Number of edges to retest : 74800
Badly formed bounding box-0.0720968 0.027 -0.0410269) (0.080055 0.027
0.0410628)#0 Foam::error::printStack(Foam:stream&) in
"/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in
Foam::indexedOctree<foam::treedatatrisurface>::div ide(Foam::treeBoundBox
const&, Foam::DynamicList<foam::list<int>, 0u, 2u, 1u>&, int) const in
"/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libmeshTools.so"
Foam::indexedOctree<foam::treedatatrisurface>::ind exedOctree(Foam::treeDataTriSu rface const&, Foam::treeBoundBox const&, int, double, double) in "/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libmeshTools.so"
#4 Foam::triSurfaceMesh::tree() const in
#5 Foam::triSurfaceMesh::findLineAny(Foam::Field<foam ::vector<double> >
const&, Foam::Field<foam::vector<double> > const&,
Foam::List<foam::pointindexhit<foam::vector<double > > >&) const in
Foam::refinementSurfaces::findHigherIntersection(F oam::Field<foam::vector<double > > const&, Foam::Field<foam::vector<double> > const&, Foam::List<int> const&, Foam::List<int>&, Foam::List<int>&) const in "/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libautoMesh.so"
#7 Foam::meshRefinement::updateIntersections(Foam::Li st<int> const&) in
#8 Foam::meshRefinement::meshRefinement(Foam::fvMesh& , double,
Foam::refinementSurfaces const&, Foam::shellSurfaces const&) in
#9 main in
"/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/snap pyHexMesh"
#10 __libc_start_main in "/lib64/libc.so.6"
#11 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat,
Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in
From function indexedOctree<type>::divide
in file lnInclude/indexedOctree.C at line 213.
FOAM aborting
The statement after line 205 in $FOAM_SRC/meshTools/lnInclude/indexedOctree.C causes the error:
if
bb.min()[0] >= bb.max()[0]
|| bb.min()[1] >= bb.max()[1]
|| bb.min()[2] >= bb.max()[2]
FatalErrorIn("indexedOctree<type>::divide")
<< "Badly formed bounding box:" << bb
<< abort(FatalError);
If this check is removed and libmeshTools recompiled, the code runs fine without errors.
Solver/Application:
snappyHexMesh
Source file:
Platform:
Linux x86_64, Fedora 9
Version:
1.5
silentdynamics GmbH - http://silentdynamics.de
open source CAE software solutions & support
hannes is offline   Reply With Quote
Old   August 1, 2008, 08:47
Default Thanks for report. The indexed
Mattijs Janssens
mattijs is on a distinguished road
Thanks for report. The indexedOctree is for 3D geometry - am surprised it actually produces something useful for 2D geometry. You might get problems with truncation error. Is it possible to get the surface, blockMeshDict and snappyHexMeshDict? (m dot janssens)
mattijs is offline   Reply With Quote
planar diffuser simulation in Fluent droper FLUENT 0 November 1, 2008 15:29
non-planar faces due to the deformation of grid gonski Main CFD Forum 5 November 12, 2007 15:25
gambit non-planar trim ahmet FLUENT 2 October 16, 2005 17:47
planar mixing layers Jitendra Main CFD Forum 5 March 19, 2002 07:59
planar conduction Ashutosh Joshi FLUENT 0 December 21, 2000 09:09
