Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
ParaFoam canbt handle cyclic boundaries in channelOodles
Old   July 17, 2008, 02:21
Default Description: The error messa
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Description:
The error message I met is,
# Error or warning: There was a VTK Error in file: /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/VTK/Filtering/vtkDataSet.cxx (383)
vtkUnstructuredGrid (0x2f06930): Point array volPointInterpolate(nuTilda) with 1 components, only has 1330 tuples but there are 1406 points
If I do not select side1, side2, inout1, inout2 in paravew, (all of these four sides are cyclic boundary), then everything goes fine.
Solver/Application:
paraFoam
Source file:
Testcase:
channelOodles/channel395
Platform:
OpenSUSE-11.0
Version:
OpenFOAM-1.5
Notes:
no
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   July 17, 2008, 12:58
Default Thanks. Was interpolation acro
Mattijs Janssens
mattijs is on a distinguished road
Thanks. Was interpolation across patches which was giving problems - now just set it up to do patch-wise interpolation. The fix is non-trivial so we'll put it out in the next patch (unless it is showstopper)
mattijs is offline   Reply With Quote
cyclic boundaries Zealouk Siemens 0 September 17, 2008 11:28
[OpenFOAM] View cyclic boundaries using MRFSimpleFoam gabriel ParaView 0 July 27, 2007 08:42
cyclic boundaries gosia stein Siemens 5 June 13, 2007 07:39
[Gmsh] Cyclic boundaries sampaio OpenFOAM Meshing & Mesh Conversion 1 February 7, 2006 13:26
CYCLIC BOUNDARIES MATCHING robert Siemens 3 September 7, 2000 01:08
