Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
TwoPhaseEulerFoam Bug
Old   February 19, 2008, 18:16
Default Hello guys, I have found a
Alex Londono
alondono is on a distinguished road
Hello guys,
I have found a minor mistake inside the code, in the KineticTheoryModel.C file, when the equilibrium switch is on, the model uses the algebraic granular temperature equation as it was proposed by Syamlal (1993), well the mistake can be found in line 321:
The original code states:
volScalarField l3 = 4.0*K4*alpha*(2.0*K3*tr2D + K2*tr2D);
But, if the original equation is reviewed, you should notice that the line must be:
volScalarField l3 = 4.0*K4*alpha*(2.0*K3*trD2 + K2*tr2D);
The equation can be checked in the MFIX Documentation and also in the B.G.M. Van Wachem PhD. Thesis.
By the way, does anyone know about new developments of this code in newer releases of OpenFOAM?
Cheers!!
Alex L.
alondono is offline   Reply With Quote
Old   February 19, 2008, 20:01
Default Bug confirmed :-) Here ther
Alberto Passalacqua
Bug confirmed :-)
Here there's the fixed file.
kineticTheoryModel.C
With kind regards,
Alberto
Alberto Passalacqua
TwoPhaseEulerFoam Documentation paul OpenFOAM Running, Solving & CFD 53 April 8, 2020 13:48
TwoPhaseEulerFoam sara OpenFOAM Running, Solving & CFD 2 November 6, 2008 19:26
Bug in twoPhaseEulerFoam alberto OpenFOAM Bugs 2 May 20, 2008 21:25
TwoPhaseEulerFOAM application hemph OpenFOAM Bugs 0 November 16, 2006 07:27
TwoPhaseEulerFoam newbee OpenFOAM 0 March 27, 2006 08:41
