Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
SimpleFoam woes
Old   April 13, 2007, 09:53
Default Description: On certain cases
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Description:
On certain cases, simpleFoam solves for U and p but for some reason does not print out the solution for velocity (i.e. BICCG solver residuals) in stdout or the redirected log file. The case in question happens to be a non-conformal 2D case. Mesh generated using blockMesh. Not sure whether this problem applies to 3D cases too?
Solver/Application: Out of the box simpleFoam -> No modifications.
Source file:
simpleFoam.C ?
Testcase:
Can be downloaded from here -> http://www.ualberta.ca/~madhavan/sample.tar.gz
Platform:
x86_64 GNU/Linux Distro: Scientific Linux 4.1 (basically an RHEL clone).
Version:
OpenFOAM version 1.3
Notes:
Related discussion thread: http://www.cfd-online.com/OpenFOAM_D...tml?1176418785
msrinath80 is offline   Reply With Quote
Old   April 13, 2007, 10:04
Default Thanks for the bug report. Th
henry is on a distinguished road
Thanks for the bug report. The issue is associated with the tolerance used in checking the dimensionality of the case. Apparently the complexity of your mesh is causing an accumulation of round-off error which means the empty patches are not exactly flat. To fix this problem edit
src/OpenFOAM/meshes/polyMesh/polyMesh.C
and in polyMesh::calcDirections() change SMALL to 1e-6 and recompile the OpenFOAM library.
alternatively download the 1.4 pack I uploaded to sourceforge today which already includes this fix.
Henry
henry is offline   Reply With Quote
Old   April 13, 2007, 10:15
Default Brilliant! Will upgrade to 1.4
Brilliant! Will upgrade to 1.4 as soon as possible. Thanks!!
What is phi in simpleFoam ehsan_vaghefi OpenFOAM Running, Solving & CFD 7 September 29, 2013 11:00
OF141dev installation Woes chegdan OpenFOAM Installation 13 July 18, 2008 17:16
Gentoo Compilation woes on AMD64 with fluentMeshToFoamL connclark OpenFOAM Installation 8 February 29, 2008 14:18
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Gambit/Iges woes Akin FLUENT 0 January 31, 2005 06:45
