Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
multiphaseInterFoam for RAS turbulence model
Old   August 27, 2009, 19:52
Default multiphaseInterFoam for RAS turbulence model
J. Cai
chiven is on a distinguished road
I am trying to run the damBreak4phase case in RAS turbulence model, however, the RAS model is uninterpreted, and the kEpsilonCoeffs are not able to be read.
I also try to use multiphaseInterFoam to calculate my case with three phases, and the same problem is met.
The terminal prompts are attached.
Have a nice day!
Chiven
Create time
Create mesh for time = 0
Reading g
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
#0 _ZN4Foam5error10printStackERNS_7OstreamE-0x1466af0
in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linuxIA64GccDPOpt/libOpenFOAM.so"
#1 _ZN4Foam6sigFpe13sigFpeHandlerEi-0x140cae0
#2 Uninterpreted:
#3 _ZNK4Foam14incompressible9RASModels33nutWallFuncti onFvPatchScalarField7calcNutEv-0x3267110
in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linuxIA64GccDPOpt/libincompressibleRASModels.so"
#4 _ZN4Foam14incompressible9RASModels33nutWallFunctio nFvPatchScalarField12updateCoeffsEv-0x326aab0
#5 Foam::fvPatchField<double>::evaluate(Foam::Pstream ::commsTypes) in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxIA64GccDPOpt/multiphaseInterFoam"
#6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxIA64GccDPOpt/multiphaseInterFoam"
#7 _ZN4Foam14incompressible9RASModels8kEpsilonC1ERKNS _14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldE NS_7volMeshEEERKNS3_IdNS_13fvsPatchFieldENS_11surf aceMeshEEERNS_14transportModelE-0x345ea40
#8 _ZN4Foam14incompressible8RASModel31adddictionaryCo nstructorToTableINS0_9RASModels8kEpsilonEE3NewERKN S_14GeometricFieldINS_6VectorIdEENS_12fvPatchField ENS_7volMeshEEERKNS6_IdNS_13fvsPatchFieldENS_11sur faceMeshEEERNS_14transportModelE-0x3410a70
#9 _ZN4Foam14incompressible8RASModel3NewERKNS_14Geome tricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volM eshEEERKNS2_IdNS_13fvsPatchFieldENS_11surfaceMeshE EERNS_14transportModelE-0x34d6870
#10 _ZN4Foam14incompressible15turbulenceModel36addturb ulenceModelConstructorToTableINS0_8RASModelEE18New turbulenceModelERKNS_14GeometricFieldINS_6VectorId EENS_12fvPatchFieldENS_7volMeshEEERKNS5_IdNS_13fvs PatchFieldENS_11surfaceMeshEEERNS_14transportModel E-0x34c0310
#11 _ZN4Foam14incompressible15turbulenceModel3NewERKNS _14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldE NS_7volMeshEEERKNS2_IdNS_13fvsPatchFieldENS_11surf aceMeshEEERNS_14transportModelE-0xe414a0
in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linuxIA64GccDPOpt/libincompressibleTurbulenceModel.so"
#12 main in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxIA64GccDPOpt/multiphaseInterFoam"
#13 __libc_start_main-0x10608e0
in "/lib/tls/libc.so.6.1"
#14 _start in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxIA64GccDPOpt/multiphaseInterFoam"
Floating exception
chiven is offline   Reply With Quote
Old   August 28, 2009, 02:39
henry is on a distinguished road
You are getting a "Floating exception" so it looks like you have not initialized the turbulence fields appropriately.
H
henry is offline   Reply With Quote
Old   August 28, 2009, 06:36
J. Cai
Hi, Dear Dr. Weller, thanks a lot for your friendly and precious comments. I am trying to improve the initialized turbulence fields. And I also try to use the laminar model to calculate my case, and when Time = 0.056, the similar error is met. Another comments?
yours sincerely,
Chiven
[7] #0 _ZN4Foam5error10printStackERNS_7OstreamE-0x18f5aa0
[7] in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linuxIA64GccDPOpt/libOpenFOAM.so"
[7] #1 _ZN4Foam6sigFpe13sigFpeHandlerEi-0x140cae0
[7] #2 Uninterpreted:
[7] #3 _ZNK4Foam10GAMGSolver13scalingFactorERNS_5FieldIdE ERKS2_S5_S5_-0x1cbddde
[7] #4 _ZNK4Foam10GAMGSolver13scalingFactorERNS_5FieldIdE ERKNS_9lduMatrixES3_RKNS_10FieldFieldIS1_dEERKNS_8 UPtrListIKNS_17lduInterfaceFieldEEERKS2_h-0x1cbd370
[7] #5 _ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9ldu Matrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_RNS1 _IS8_EESD_h-0x1cb6b00
[7] #6 _ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h-0x1cb58a0
[7] #7 _ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE-0x2a75610
[7] in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linuxIA64GccDPOpt/libfiniteVolume.so"
[7] #8 main in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxIA64GccDPOpt/multiphaseInterFoam"
[7] #9 __libc_start_main-0x14ef870
[7] in "/lib/tls/libc.so.6.1"
[7] #10 _start in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxIA64GccDPOpt/multiphaseInterFoam"
[jaeri02:26701] *** Process received signal ***
[jaeri02:26701] Signal: Floating point exception (8)
[jaeri02:26701] Signal code: (-6)
[jaeri02:26701] Failing at address: 0x2d330000684d
[jaeri02:26701] [ 0] [0xa0000000000107e0]
[jaeri02:26701] [ 1] [0xa000000000010641]
[jaeri02:26701] [ 2] /lib/tls/libc.so.6.1(gsignal-0x14c8360) [0x2000000002705190]
[jaeri02:26701] [ 3] /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linuxIA64GccDPOpt/libOpenFOAM.so(_ZN4Foam6sigFpe13sigFpeHandlerEi-0x140cad0) [0x20000000022c1eb0]
[jaeri02:26701] [ 4] [0xa0000000000107e0]
[jaeri02:26701] [ 5] /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linuxIA64GccDPOpt/libOpenFOAM.so(_ZNK4Foam10GAMGSolver13scalingFacto rERNS_5FieldIdEERKS2_S5_S5_-0x1cbddde) [0x2000000001f0f692]
[jaeri02:26701] [ 6] /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linuxIA64GccDPOpt/libOpenFOAM.so(_ZNK4Foam10GAMGSolver13scalingFacto rERNS_5FieldIdEERKNS_9lduMatrixES3_RKNS_10FieldFie ldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEE RKS2_h-0x1cbd370) [0x2000000001f10110]
[jaeri02:26701] [ 7] /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linuxIA64GccDPOpt/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7 PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS 8_S9_S9_S9_RNS1_IS8_EESD_h-0x1cb6b00) [0x2000000001f16990]
[jaeri02:26701] [ 8] /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linuxIA64GccDPOpt/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5Fi eldIdEERKS2_h-0x1cb58a0) [0x2000000001f17c00]
[jaeri02:26701] [ 9] /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linuxIA64GccDPOpt/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS _10dictionaryE-0x2a75610) [0x2000000001157ea0]
[jaeri02:26701] [10] multiphaseInterFoam [0x40000000000c8560]
[jaeri02:26701] [11] /lib/tls/libc.so.6.1(__libc_start_main-0x14ef870) [0x20000000026ddc50]
[jaeri02:26701] [12] multiphaseInterFoam [0x4000000000023fa0]
[jaeri02:26701] *** End of error message ***
mpirun noticed that process rank 7 with PID 26701 on node jaeri02 exited on signal 8 (Floating point exception).
Old   August 31, 2009, 02:43
J. Cai
Hello, Dear Dr. Weller, now the liminar model is OK for the damBreak4phase case and my case. For the RASModel, I try to initialize the turbulence fields again, like the U, k, and epsilon, but fail and the same error is met. The BC setting is show in follows. The k and epsilon are obtained from
k=1.5*(5%*Ux)^2
epsilon=(Cmut^2*k^1.5)/(0.07*Dc), Dc is diameter
The k and epsilon setting way is OK for the single-phase turbulence calculation.
I also have tried to use boxtocell to set the fields of U, k,and epsilon.
Now, I have no idea about this problem. Especially I am amazing why the kEpsilonCoeffs{Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3;} can NOT be read.
Thank you very much!
Best regards,
Chiven
Old   April 7, 2011, 07:05
Sarah Köhler
sarahk is on a distinguished road
Hey Guys,
did you figured out how to run multiphaseInterFoam with RASModel?
I get almost the same message!
Thanks in advance
sarah
sarahk is offline   Reply With Quote
Old   August 22, 2011, 22:25
mali is on a distinguished road
Hi All,
I got the same problem. Any updated solution to this turbulent initial condition for multiphase dambreak problems?
mali
mali is offline   Reply With Quote
Old   August 23, 2011, 02:38
Hi All,
After many attempts, I found that by setting the boundaryfiled of the /nut to zeroGradient, the simulation run without any error.
Cheers
mali
Old   August 23, 2011, 02:52
Sarah Köhler
Hey mali,
nice, thanks a lot!
Do you use zeroGradient just for the walls, or for in- and Outlet as well?
Greetings
sarah
Old   December 6, 2017, 02:08
Elham
Elham is on a distinguished road
Would you please someone explain to me what the following part of multiphaseInterFoam mean?
    forAllIter(PtrDictionary<phase>, phases_, iter)
        phase& alpha = iter();
Cheers,
Elham
Elham is offline   Reply With Quote
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 22:43
Eul-Eul flow, k-e-kp-ep-Theta Turbulence model us FLUENT 5 April 5, 2011 02:29
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
validating turbulence model on flow around a car Pedro CFX 1 February 20, 2008 16:32
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
