Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
About chtMultiRegionFoam in parallel (v1.6)
Old   September 9, 2009, 22:31
Default About chtMultiRegionFoam in parallel (v1.6)
Zheng.Zhi
Zheng.Zhi is on a distinguished road
When I use chtMultiRegionFoam to solve multiRegionHeater case in parallel, I want to set topAir_to_heater with kqRWallFunction and epsilonWallFunction boundary conditions. But there was the error said topAir_to_heater must be wall instead of directMappedWall. Is there any method to solver this problem?
Thanks!
Zheng.Zhi is offline   Reply With Quote
Old   September 10, 2009, 04:37
Mattijs Janssens
mattijs is on a distinguished road
Do you get this error running non-parallel as well?
mattijs is offline   Reply With Quote
Old   September 10, 2009, 05:14
Zheng.Zhi
Yes,maybe the problem is the wall function needs wallFvPatch , but the directMappedWall is wallPolyPatch ?
Old   September 10, 2009, 07:25
Mattijs Janssens
directMappedWall is derived from wallPolyPatch. The problem was that the finite volume equivalent wasn't derived from wallFvPatch. I pushed a fix to 1.6.x. Give it a go.
Thanks for reporting.
Old   September 15, 2009, 06:00
Xinyuan FAN
autumn1012 is on a distinguished road
Here is another problem when I tried 1.6.x,
Solving for fluid region bottomAir
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 2.211858e-16, Final residual = 2.211858e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 6.771384e-09, No Iterations 22
DILUPBiCG: Solving for Uz, Initial residual = 1.036037e-15, Final residual = 1.036037e-15, No Iterations 0
DILUPBiCG: Solving for h, Initial residual = 0.6044857, Final residual = 8.30665e-09, No Iterations 40
Min/max T:300 300
GAMG: Solving for p, Initial residual = 1, Final residual = 0.005459487, No Iterations 2
time step continuity errors (bottomAir): sum local = 0.001237545, global = 4.109187e-06, cumulative = 4.109187e-06
GAMG: Solving for p, Initial residual = 0.6006277, Final residual = 6.905954e-09, No Iterations 27
time step continuity errors (bottomAir): sum local = 2.018032e-09, global = -4.377309e-11, cumulative = 4.109143e-06
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/fxy/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/fxy/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 Foam::compressible::RASModels::epsilonWallFunction FvPatchScalarField::updateCoeffs() in "/home/fxy/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#4 Foam::compressible::RASModels::kEpsilon::correct() in "/home/fxy/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#5 main in "/home/fxy/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/chtMultiRegionFoam"
#6 __libc_start_main in "/lib64/libc.so.6"
#7 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Floating point exception
Then I checked epsilonWallFunctionFvPatchScalarField and found there are some calculations like this
const scalarField& y = rasModel.y()[patch().index()];
forAll(nutw, faceI)
epsilon[faceCellI] = Cmu75*pow(k[faceCellI], 1.5)/(kappa_*y[faceI]);
So I modified chtMultiRegionFoam to output rasModel.y() of patch like bottomAir_to_heater, then I found all of them are 0, so the above error happened.
Is there any method to solver this problem? Thanks.
autumn1012 is offline   Reply With Quote
Old   September 15, 2009, 10:47
Mattijs Janssens
I've just pushed a lot of changes to 1.6.x to do with wall-type recognition. Could you try again?
Thanks,
Mattijs
Old   September 15, 2009, 21:50
Xinyuan FAN
Ok, I will give a reply when I try again.
Old   September 16, 2009, 01:46
Xinyuan FAN
The problem has been solved. The multiRegionHeater case can be running in both non-parallel and parallel. Thank you for your update.
Old   October 14, 2009, 03:39
cvv
Carel
cvv is on a distinguished road
Can someone perhaps post a link to the tutorial for chtMultiRegionFoam in 1.6? I tried the one from 1.5 but get the following error when I run the solver:
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
Not Implemented
Trying to construct an genericFvPatchField on patch bottomAir_to_rightSolid of field h#0 Foam::error:rintStack(Foam::Ostream&) at /opt/Op enFOAM/r1.6/debug/OpenFOAM-1.6/src/OSspecific/POSIX/printStack.C:203
I read on another thread that this may be due to the boundary type. In this case the type is solidWallTemperatureCoupled. Was this changed in 1.6?
Regards
Carel
cvv is offline   Reply With Quote
Old   October 14, 2009, 08:20
cvv
Carel
..never mind, just did not read the instructions!
It is working now.
Old   November 16, 2009, 12:46
Tobias Holzinger
woody is on a distinguished road
Hello Mattijs,
are there other BC's like directMappedWall to make two regions interact?
Thanks
Tobias
woody is offline   Reply With Quote
Parallel Moving Mesh Bug for Multi-patch Case albcem OpenFOAM Bugs 17 April 28, 2013 23:44
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
