Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
1.5-dev Revision r1629 does not build
Old   February 8, 2010, 06:14
Default 1.5-dev Revision r1629 does not build
BastiL
bastil is on a distinguished road
... Problem is a change in the file:
src/meshTools/Make/options. This requires decompositionMethods which is compiled later. The change has been done with r1618.
Regards BastiL
bastil is offline   Reply With Quote
Old   February 9, 2010, 04:23
Hrvoje Jasak
Apologies - I rarely bulid from clean.
Could you please try the following and tell me if it's OK.
Thank you.
Hrv
#!/bin/sh
set -x
( cd OpenFOAM && wmakeLnInclude . )
( cd Pstream && ./Allwmake )
wmake libo OSspecific/$WM_OS
wmake libso OpenFOAM
( cd decompositionAgglomeration && ./Allwmake )
wmake libso lagrangian/basic
wmake libso triSurface
wmake libso edgeMesh
wmake libso meshTools
wmake libso finiteVolume
wmake libso finiteArea
wmake libso lduSolvers
wmake libso dynamicMesh
( cd tetDecompositionFiniteElement ; ./Allwmake )
wmake libso fvMotionSolver
( cd tetDecompositionMotionSolver; ./Allwmake )
wmake libso coupledMatrix
wmake libso sampling
wmake libso dynamicFvMesh
wmake libso topoChangerFvMesh
wmake libso engine
wmake libso ODE
wmake libso randomProcesses
( cd thermophysicalModels && ./Allwmake )
( cd transportModels && ./Allwmake )
( cd turbulenceModels && ./Allwmake )
( cd lagrangian && ./Allwmake )
( cd postProcessing && ./Allwmake )
( cd conversion && ./Allwmake )
wmake libso autoMesh
wmake libso errorEstimation
# ----------------------------------------------------------------- end-of-file
Hrvoje Jasak
Old   February 9, 2010, 05:32
BastiL
I will do and I will get back to you.
I thought it was essential to build from clean so thats what I usually do. Is it save to run Allwmake without cleaning? Thanks.
Old   February 9, 2010, 06:20
BastiL
SOURCE=directMapped/directMappedPointPatch/directMappedPointPatch.C ;  g++ -m64 -Dlinux64 -DDP -DFOAM_DEV_REVISION_NUMBER=1629 -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3  -DNoRepository -ftemplate-depth-40 -I/home/OpenFOAM/test/OpenFOAM-1.5-dev/src/triSurface/lnInclude -I/home/OpenFOAM/test/OpenFOAM-1.5-dev/src/decompositionAgglomeration/decompositionMethods/decompositionMethod/ -I/home/OpenFOAM/test/OpenFOAM-1.5-dev/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/home/OpenFOAM/test/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/OpenFOAM/test/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/directMappedPointPatch.o
/usr/bin/ld: cannot find -ldecompositionMethods
collect2: ld returned 1 exit status
Problem still remains
Old   February 9, 2010, 08:05
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Bastil
This error reminds my of something. I believe the problem was, that the ThirdParty directories was build as part of the openCFD-release. Recompiling the ThirdParties with -dev settings solved my problem.
Good luck,
Niels
ngj is offline   Reply With Quote
Old   February 9, 2010, 10:56
BastiL
I can compile any pre-r1618 (currently have r1617) w.o. any problems.
OpenFOAM 1.5 dev LVDH OpenFOAM 98 May 5, 2010 17:01
[OpenFOAM] ParaView/ParaFoam in OpenFoam 1.5 dev titio ParaView 2 February 27, 2010 14:02
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 12:13
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 12:12
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
