Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
HashTable Binary write format
Old   March 15, 2010, 14:23
Default HashTable Binary write format
Sandeep Menon
deepsterblue will become famous soon enough
Not sure if this is a bug, but nevertheless...
It appears that HashTable contents cannot be written in binary format to disk (but ascii with either compressed/uncompressed works just fine). Is this a limitation of the binary format (due to coding complications, etc)? Or has it just not been implemented yet?
With the write-option in controlDict set to binary, the HashTable header specifies "binary", but the contents are still in ASCII form. This becomes problematic during the re-read from disk.
I'm using 1.5-dev, by the way...
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   March 16, 2010, 10:03
henry is on a distinguished road
I have tested binary IO of HashTable in OpenFOAM-1.6.x and it works fine. Are you able to reproduce the problem in OpenFOAM-1.6.x? If so could you send a code example which reproduces the problem?
H
henry is offline   Reply With Quote
How to write Tecplot binary file(.plt) in CFD code on Linux 64 platform? markailee Tecplot 5 December 16, 2010 07:03
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 08:42
Binary File format for Tecplot CFD Student Tecplot 3 February 27, 2006 05:29
Who can write the binary diffusion coefficient ?? Hsin-Ping FLUENT 1 April 15, 2002 02:22
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 15:52
