Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
octreeLine.getIntersections() causes compile error in OF 1.7.x
Old   June 7, 2011, 17:03
Default octreeLine.getIntersections() causes compile error in OF 1.7.x
Ryan Danks
RDanks is on a distinguished road
Hi Foamers,
I'm trying to do some simple shadowing in openFOAM using ray-casting. Obviously, I'd rather use the built in octree classes to speed this process up rather than doing a brute force check of every patch face against the points I want to get shading data for. To this end I tried to impliment the octreeLine class with it's getIntersections() method, (http://foam.sourceforge.net/doc/Doxy...ctreeLine.html) to get a list of the cells intersected by a given line.
I followed the exact same setup as shown on octreeLine's Doxygen page but whenever I compile I get all kinds of errors that look like they reside in the base OF code. (See attachment for the output)
Has anyone successfully used this method or is this a bug in the code? Thanks!
RDanks is offline   Reply With Quote
Old   June 8, 2011, 09:55
Default Fixed it
Ryan Danks
Hey everyone,
After a night's rest I found the problem.
The pointHitSort class didn't have a " < " operator defined in pointHitSort.H, the std::sort algorithm needs this to sort the intersections the lineSearch finds.
If you add the following to pointHitSort.H everything compiles fine...
bool operator<(const pointHitSort& rhs) const
    return inter_.distance() < rhs.inter().distance();
Old   July 19, 2011, 05:41
aot
Andreas Otto
aot is on a distinguished road
i also want to include some ray-casting in OF. Up to now I used some brute force searching with findcell. Have you been successful with using getintersections and is it possible to get some more information on your implementation (or at best some code snippets)?
aot is offline   Reply With Quote
Old   July 19, 2011, 08:25
Ryan Danks
Hi Andreas,
Basically my implementation is the same as one outlined on the Doxygen page for the octreeLine class...
octree<octreeDataFace> oc( .. );
octreeLine<octreeDataFace> lineSearch(oc, pStart, pEnd);
while (lineSearch.getIntersection())
    const point& pt = lineSearch.hitInfo().hitPoint();
You generate an octree of faces that could block your rays, and another one for the cells. Then you use octreeLine to see if there is an intersection between each cell centre and your ray source.
There's not much more to it than that. The built in octree classes are quite fast and I've had some good results working with it.
Originally Posted by aot View Post
Old   July 19, 2011, 09:28
aot
Andreas Otto
Hi Ryan,
thanks for the quick answer. How do you generate those octrees? Up to now I don't have any experience in working with octree-classes and there is merely any discussion on this topic in the forum.
Thanks
Andreas
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
star4ToFoam Segfault on Mac OS X 10.6.5 / OF 1.7.x sushant OpenFOAM Installation 1 December 25, 2010 19:38
PV3FoamReader compile error.... PEM_GUY OpenFOAM Installation 6 April 5, 2010 17:22
Error compile file udf czfluent Fluent UDF and Scheme Programming 24 September 26, 2009 13:24
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
