Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solidMechanics] Running contactStressFoam in Parallel
Old   October 15, 2012, 12:06
Default Running contactStressFoam in Parallel
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Dear Foamers,
I have compiled the contactStressFoam solver on OpenFOAM 2.0.1. The ball and brick tutorial runs OK in serial. However, when I try to run it in parallel (using 4 cpus and scotch) I get the following error running it with valgrind:
==18787== Memcheck, a memory error detector
==18787== Copyright (C) 2002-2010, and GNU GPL'd, by Julian Seward et al.
==18787== Using Valgrind-3.6.1 and LibVEX; rerun with -h for copyright info
==18787== Command: mpirun -np 4 contactStressFoam -parallel
==18787==
==18787== Syscall param sched_setaffinity(mask) points to unaddressable byte(s)
==18787==    at 0x55D65D9: syscall (syscall.S:39)
==18787==    by 0x609253B: ??? (in /usr/lib/openmpi/lib/openmpi/mca_paffinity_linux.so)
==18787==    by 0x609291C: ??? (in /usr/lib/openmpi/lib/openmpi/mca_paffinity_linux.so)
==18787==    by 0x6093439: ??? (in /usr/lib/openmpi/lib/openmpi/mca_paffinity_linux.so)
==18787==    by 0x60923AF: ??? (in /usr/lib/openmpi/lib/openmpi/mca_paffinity_linux.so)
==18787==    by 0x50B9C5E: opal_paffinity_base_select (in /usr/lib/openmpi/lib/libopen-pal.so.0.0.0)
==18787==    by 0x508F866: opal_init (in /usr/lib/openmpi/lib/libopen-pal.so.0.0.0)
==18787==    by 0x4E3C9F4: orte_init (in /usr/lib/openmpi/lib/libopen-rte.so.0.0.0)
==18787==    by 0x403046: ??? (in /usr/bin/orterun)
==18787==    by 0x402BC3: ??? (in /usr/bin/orterun)
==18787==    by 0x5510EFE: (below main) (libc-start.c:226)
==18787==  Address 0x0 is not stack'd, malloc'd or (recently) free'd
==18787==
|  \\    /   O peration     | Version:  2.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : 2.0.1-cce6c678443c
Exec   : contactStressFoam -parallel
Date   : Oct 15 2012
Time   : 18:03:21
Host   : numubuntu-System-Product-Name
PID    : 18790
Case   : /home/hisham/OpenFOAM/OpenFOAM-1.6-ext/tutorials/stressAnalysis/contactStressFoam/ballAndBrick
nProcs : 4
Slaves :
3
numubuntu-System-Product-Name.18791
numubuntu-System-Product-Name.18792
numubuntu-System-Product-Name.18793
Pstream initialized with:
    floatTransfer     : 0
    nProcsSimpleSum   : 0
    commsType         : nonBlocking
fileModificationChecking : Monitoring run-time modified files using timeStamp
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
[1] #0  Foam::error::printStack(Foam::Ostream&)[0] #0  Foam::error::printStack(Foam::Ostream&)// using new solver syntax:
U
    solver          PCG;
    preconditioner  DIC;
    tolerance       1e-05;
    relTol          0.01;
Reading field U
Reading material properties
Normalising E : E/rho
Reading boundary conditions
Reading patchPressure
Normalising patchPressure : patchPressure/rho
Reading patchTraction
Normalising patchTraction : patchTraction/rho
Calculating Lame's coefficients
Plane Strain
mu = 9.79413e+06 Pa/rho
lambda = 1.46912e+07 Pa/rho
Calculating patch traction
Reading contact patch IDs etc.
Creating contact pairs
Calculating displacement field
Iteration: 1
[2] #0  Foam::error::printStack(Foam::Ostream&)[3] #0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #1  Foam::sigSegv::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #1  Foam::sigSegv::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #1  Foam::sigSegv::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #1  Foam::sigSegv::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #2   in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #2  [1] #2   in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #2   in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #3   in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3   in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3   in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #3
[3]  in "/home/hisham/OpenFOAM/hisham-2.0.1/platforms/linux64GccDPOpt/bin/contactStressFoam"
[3] #4
[0]  in "/home/hisham/OpenFOAM/hisham-2.0.1/platforms/linux64GccDPOpt/bin/contactStressFoam"
[0] #4  [1]  in "/home/hisham/OpenFOAM/hisham-2.0.1/platforms/linux64GccDPOpt/bin/contactStressFoam"
[1] #4
[2]  in "/home/hisham/OpenFOAM/hisham-2.0.1/platforms/linux64GccDPOpt/bin/contactStressFoam"
[2] #4
[0] #5  [1]  in "/home/hisham/OpenFOAM/hisham-2.0.1/platforms/linux64GccDPOpt/bin/contactStressFoam"
[1] #5
[3] #5
[2] #5
[0] #6  [1]  in "/home/hisham/OpenFOAM/hisham-2.0.1/platforms/linux64GccDPOpt/bin/contactStressFoam"
[1] #6
[3] #6
[2] #6
[1]  in "/home/hisham/OpenFOAM/hisham-2.0.1/platforms/linux64GccDPOpt/bi[0]  in "/home/hisham/OpenFOAM/hisham-2.0.1/platforms/linux64GccDPOpt/bin/contactStressFoam"
[0] #7  n/contactStressFoam"
[1] #7
[3] #7
[2] #7
[1]  in "/home/hisham/OpenFOAM/hisham-2.0.1/platforms/linux64GccDPOpt/bin/con[0]  in "/home/hisham/OpenFOAM/hisham-2.0.1/platforms/linux64GccDPOpt/bin/contactStressFoatactStressFoam"
[1] #8  __libc_start_mainm"
[0] #8  __libc_start_main
[1] #9   in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #9  [3]  in "/home/hisham/OpenFOAM/hisham-2.0.1/platforms/linux64GccDPOpt/bin/contactStressFoam"
[3] #8  __libc_start_main[2]  in "/home/hisham/OpenFOAM/hisham-2.0.1/platforms/linux64GccDPOpt/bin/contactStressFoam"
[2] #8  __libc_start_main
[3] #9   in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #9  [1]  in "/home/hisham/OpenFOAM/hisham-2.0.1/platforms/linux64GccDPOpt/bin/contactStressFoam"
[numubuntu-System-Product-Name:18791] *** Process received signal ***
[numubuntu-System-Product-Name:18791] Signal: Segmentation fault (11)
[numubuntu-System-Product-Name:18791] Signal code:  (-6)
[numubuntu-System-Product-Name:18791] Failing at address: 0x3e900004967
[numubuntu-System-Product-Name:18791] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x33d80) [0x7f38318cfd80]
[numubuntu-System-Product-Name:18791] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f38318cfd05]
[numubuntu-System-Product-Name:18791] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x33d80) [0x7f38318cfd80]
[numubuntu-System-Product-Name:18791] [ 3] contactStressFoam() [0x4241a5]
[numubuntu-System-Product-Name:18791] [ 4] contactStressFoam() [0x4249fa]
[numubuntu-System-Product-Name:18791] [ 5] contactStressFoam() [0x425e92]
[numubuntu-System-Product-Name:18791] [ 6] contactStressFoam() [0x41da07]
[numubuntu-System-Product-Name:18791] [ 7] contactStressFoam() [0x42e92b]
[numubuntu-System-Product-Name:18791] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xff) [0x7f38318baeff]
[numubuntu-System-Product-Name:18791] [ 9] contactStressFoam() [0x41cc79]
[numubuntu-System-Product-Name:18791] *** End of error message ***
[numubuntu-System-Product-Name:18790] *** Process received signal ***
[numubuntu-System-Product-Name:18790] Signal: Segmentation fault (11)
[numubuntu-System-Product-Name:18790] Signal code:  (-6)
[numubuntu-System-Product-Name:18790] Failing at address: 0x3e900004966
[numubuntu-System-Product-Name:18790] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x33d80) [0x7fd76cfc6d80]
[numubuntu-System-Product-Name:18790] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7fd76cfc6d05]
[numubuntu-System-Product-Name:18790] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x33d80) [0x7fd76cfc6d80]
[numubuntu-System-Product-Name:18790] [ 3] contactStressFoam() [0x4241a5]
[numubuntu-System-Product-Name:18790] [ 4] contactStressFoam() [0x4249fa]
[numubuntu-System-Product-Name:18790] [ 5] contactStressFoam() [0x425e92]
[numubuntu-System-Product-Name:18790] [ 6] contactStressFoam() [0x41da07]
[numubuntu-System-Product-Name:18790] [ 7] contactStressFoam() [0x42e92b]
[numubuntu-System-Product-Name:18790] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xff) [0x7fd76cfb1eff]
[numubuntu-System-Product-Name:18790] [ 9] contactStressFoam() [0x41cc79]
[numubuntu-System-Product-Name:18790] *** End of error message ***
[numubuntu-System-Product-Name:18792] *** Process received signal ***
[numubuntu-System-Product-Name:18792] Signal: Segmentation fault (11)
[numubuntu-System-Product-Name:18792] Signal code:  (-6)
[numubuntu-System-Product-Name:18792] Failing at address: 0x3e900004968
[numubuntu-System-Product-Name:18792] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x33d80) [0x7f66112a6d80]
[numubuntu-System-Product-Name:18792] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f66112a6d05]
[numubuntu-System-Product-Name:18792] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x33d80) [0x7f66112a6d80]
[numubuntu-System-Product-Name:18792] [ 3] contactStressFoam() [0x4241a5]
[numubuntu-System-Product-Name:18792] [ 4] contactStressFoam() [0x4249fa]
[numubuntu-System-Product-Name:18792] [ 5] contactStressFoam() [0x425e92]
[numubuntu-System-Product-Name:18792] [ 6] contactStressFoam() [0x41da07]
[numubuntu-System-Product-Name:18792] [ 7] contactStressFoam() [0x42e948]
[numubuntu-System-Product-Name:18792] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xff) [0x7f6611291eff]
[numubuntu-System-Product-Name:18792] [ 9] contactStressFoam() [0x41cc79]
[numubuntu-System-Product-Name:18792] *** End of error message ***
[numubuntu-System-Product-Name:18793] *** Process received signal ***
[numubuntu-System-Product-Name:18793] Signal: Segmentation fault (11)
[numubuntu-System-Product-Name:18793] Signal code:  (-6)
[numubuntu-System-Product-Name:18793] Failing at address: 0x3e900004969
[numubuntu-System-Product-Name:18793] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x33d80) [0x7f184c04ed80]
[numubuntu-System-Product-Name:18793] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f184c04ed05]
[numubuntu-System-Product-Name:18793] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x33d80) [0x7f184c04ed80]
[numubuntu-System-Product-Name:18793] [ 3] contactStressFoam() [0x4241a5]
[numubuntu-System-Product-Name:18793] [ 4] contactStressFoam() [0x4249fa]
[numubuntu-System-Product-Name:18793] [ 5] contactStressFoam() [0x425e92]
[numubuntu-System-Product-Name:18793] [ 6] contactStressFoam() [0x41da07]
[numubuntu-System-Product-Name:18793] [ 7] contactStressFoam() [0x42e948]
[numubuntu-System-Product-Name:18793] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xff) [0x7f184c039eff]
[numubuntu-System-Product-Name:18793] [ 9] contactStressFoam() [0x41cc79]
[numubuntu-System-Product-Name:18793] *** End of error message ***
mpirun noticed that process rank 1 with PID 18791 on node numubuntu-System-Product-Name exited on signal 11 (Segmentation fault).
2 total processes killed (some possibly by mpirun during cleanup)
==18787==
==18787== HEAP SUMMARY:
==18787==     in use at exit: 266,137 bytes in 1,614 blocks
==18787==   total heap usage: 10,283 allocs, 8,669 frees, 15,766,629 bytes allocated
==18787==
==18787== LEAK SUMMARY:
==18787==    definitely lost: 34,567 bytes in 73 blocks
==18787==    indirectly lost: 2,716 bytes in 64 blocks
==18787==      possibly lost: 0 bytes in 0 blocks
==18787==    still reachable: 228,854 bytes in 1,477 blocks
==18787==         suppressed: 0 bytes in 0 blocks
==18787== Rerun with --leak-check=full to see details of leaked memory
==18787==
==18787== For counts of detected and suppressed errors, rerun with: -v
==18787== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 4 from 4)
I appreciate any help!
Edit: The solver does not execute in parallel when compiled in an OpenFOAM-1.6-ext environment as well. It reports the same error.
Best regards,
Hisham
Hisham is offline   Reply With Quote
Old   October 16, 2012, 10:27
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Hisham,
This solver has not been developed for parallel simulation. In fact, this solver does not work in serial (there are a couple of mistakes in the procedure).
The solver elasticContactSolidFoam (found in the solidMechanics branch of OpenFOAM-1.6-ext) runs in parallel by employing special procedures in combination with globalFaceZones.
Best regards,
Philip
bigphil is offline   Reply With Quote
Old   October 16, 2012, 10:34
Hisham's Avatar
Hisham Elsafti
Originally Posted by bigphil View Post
Hi Hisham,
Best regards,
Philip
Thanks a lot Philip ... It is wonderful what you have done ... Respect to you, sir
contact, contactstressfoam, newcontactstressfoam, openfoam, stress analysis
[Other] blueCFD-Core-2016 user compiled solvers not running in parallel sbence OpenFOAM Installation 10 December 5, 2018 08:44
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 16:38
error while running in parallel using openmpi on local mc 6 processors suryawanshi_nitin OpenFOAM 10 February 22, 2017 21:33
Fluent 14.0 file not running in parallel mode in cluster tejakalva FLUENT 0 February 4, 2015 07:02
Problems running in parallel - missing controlDict Argen OpenFOAM Running, Solving & CFD 4 June 7, 2012 03:50
