Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[FSI] FSI + Rigid body impact
Old   May 15, 2017, 04:45
Default FSI + Rigid body impact
Lucas Ribeiro
Warlord is on a distinguished road
Hello folks,
I have extended the Fluid-Solid Interaction toolkit[Tuković at al] of foam-extend 3.1 to support nonNewtonian fluids. The implementation is verified and is correct. Now, I would like to simulate an impact using it. A hemispherical impactor would fall impacting on a brick made of elastic material with non-Newtonian fluid confined inside of it.
The impactor is made of steel and is would be modeled basically as a rigid body.
How could I simulate the impact between a rigid body and the already implemented elastic material? Does anyone has a guideline? Or just a starting point?
The concept:
Thanks
Warlord is offline   Reply With Quote
Old   February 9, 2019, 20:35
aow
Andrew O. Winter
aow is on a distinguished road
Hello Lucas,
It's been some time since you posted this so I'm wondering if you made any progress towards your goal? If so, could you give some direction as to how you either used existing OpenFOAM functionality and/or added new code on your own to make things work?
I'm thinking of trying to simulate rigid bodies colliding with one another and in the future moving towards elastic bodies; however, as far as I can tell this sort of functionality is not available at present in OpenFOAM.
Best regards,
Andrew
aow is offline   Reply With Quote
Old   February 11, 2019, 06:22
Lucas Ribeiro
Hello Andrew,
I am still working on this. I am using a very nice toolbox, called solids4foam, for foam-extend. It has support for solid simulation and very basic support for contact boundary condition. I suggest you to look at https://www.researchgate.net/project/The-finite-volume-method-for-solid-mechanics for more information about solid simulation using the FVM framework.
Makes no sense to simulate rigid bodies colliding with FVM/FEM, since they were created to simulate deforming media. And collision between elastic bodies has not been the focus of FVM researches. Are you sure you want to simulate this using FVM? The FEM framework is very mature, compared with FVM, to simulate such things.
Best regards,
Lucas
Old   July 29, 2022, 08:40
Ashish Magar
ashishmagar600 is on a distinguished road
Hi Lucas,
Have you made any progress in this regard? Also isn't solids4Foam based on FVM, do you know any open source libs based on FEM to be used for impact simulations?
Thanks
ashishmagar600 is offline   Reply With Quote
fsi, impact, projectile, rigid bodies
6-DoF Rigid Body Motion jumpa72 OpenFOAM Running, Solving & CFD 6 March 1, 2024 02:38
Two Way FSI of Highly Flexible Body Sunny Chitti Structural Mechanics 0 June 27, 2017 14:22
force convergence problems in CFX 6DOF rigid body solver ajay_ks CFX 8 March 25, 2013 04:02
Rigid body fsi akash1016 FLUENT 0 August 19, 2012 08:19
Rigid body Birkov CFX 4 May 25, 2012 06:26
