Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solids4Foam] Solids4Foam with Immersed Boundary?
Like Tree1Likes
  • 1 Post By treem22
Old   October 29, 2020, 11:00
Default Solids4Foam with Immersed Boundary?
Mike Tree
treem22 is on a distinguished road
I'm attempting to simulate flow through an aortic valve. At certain time points throughout the simulation the valve will be closed. This obviously creates issues with conformal mesh motion. Is it possible to run solids4Foam with an immersed boundary (or overset) solver, which may handle the closed valve geometry easier? If so, will solids4Foam consider the contact forces between the closing heart valve leaflets?
IvanLu likes this.
treem22 is offline   Reply With Quote
UDF for Automatic Solution Initialization for previous case data file gartz89 Fluent UDF and Scheme Programming 6 March 30, 2020 07:38
[ImmersedBoundary] Immersed Boundary foam-ext 3.2 Parallelization for higher amount of MPI tasks hxaxtma OpenFOAM Community Contributions 1 October 12, 2019 09:34
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
