what is the importance of deltaT and endTime entries in system/solid/controlDict? |
February 9, 2020, 12:48 |
Ali Shayegh
Rep Power: 10 |
Honored solidFoamers,
I am a little bit confused about the solids4Foam algorithm during an FSI simulation. The main question is what is the importance of deltaT and endTime entries in system/solid/controlDict ? My understanding is as follows: 1- Fluid is solved in the current timeStep (specified in system/controlDict.deltaT). 2- Forces are applied on the solid and the displacement is calculated for THIS TIMESTEP, but WHICH TIMESTEP? The one that is specified in system/controlDict or the other one in system/solid/controlDict? 3- ... ... This question can be asked in another way: In an FSI simulation, is it not enough to solve fluid in a transient manner and solve solid in a steady manner at the same time step? If solids4Foam does so, why, for example in elastic beam tutorial, d2dt2Scheme is specified as Euler and not steadyState ? Kind Regards, Ali |
cannot set exact 'endtime' in controlDict when using a steady state solver | minecraftgp | OpenFOAM Running, Solving & CFD | 4 | July 24, 2018 05:13 |
InterFoam (PimpleFoam) not obeying DeltaT in ControlDict | walakaka | OpenFOAM Running, Solving & CFD | 2 | March 1, 2018 12:57 |
deltaT does not change with pimpleDyMFoam | rcastilla | OpenFOAM Running, Solving & CFD | 3 | June 8, 2016 06:50 |
query regarding deltaT in multiphaseEulerFoam | bigboss.abhishek | OpenFOAM Running, Solving & CFD | 6 | September 24, 2015 15:56 |
interDyMFoam deltaT drops non-stop | Virtual-iCFD | OpenFOAM Running, Solving & CFD | 5 | June 12, 2015 04:30 |
