Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
Finding Q and vorticity for FSI case
Like Tree3Likes
  • 1 Post By bigphil
  • 2 Post By MFWilliams
Old   March 24, 2022, 05:32
Default Finding Q and vorticity for FSI case
Merlin Williams
MFWilliams is on a distinguished road
Hello all,
I am stuck trying to post process the results of my FSI simulation to try get data for Q and vorticity.
I have managed to get wall shear stress data by using 'wallShearStresss -region fluid', but that does not work for Q or vorticity and I get the output:
options:
  -DebugSwitches <key1=val1,key2=val2,...>
  -DimensionedConstants <key1=val1,key2=val2,...>
  -InfoSwitches <key1=val1,key2=val2,...>
  -OptimisationSwitches <key1=val1,key2=val2,...>
  -Tolerances <key1=val1,key2=val2,...>
  -case <dir>       specify alternate case directory, default is the cwd
  -constant         include the 'constant/' dir in the times list
  -dict <dictionary name>
  -dumpControlSwitches
  -latestTime       select the latest time
  -newTimes         select the new times
  -noFunctionObjects
                    do not execute functionObjects
  -noWrite
  -noZero           exclude the '0/' dir from the times list, has precedence
                    over the -withZero option
  -parallel         run in parallel
  -roots <(dir1 .. dirN)>
                    slave root directories for distributed running
  -time <ranges>    comma-separated time ranges - eg, ':10,20,40:70,1000:'
  -srcDoc           display source code in browser
  -doc              display application documentation in browser
  -help             print the usage
Using: foam-extend-4.1 (see www.foam-extend.org)
Build: 4.1-70b064d0f326
Please can somebody please help me to find Q and vorticity from an already completed simulation.
Best regards
Merlin
MFWilliams is offline   Reply With Quote
Old   March 24, 2022, 08:00
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Inconveniently, many of the utilities do not yet have the "-region" option.
So your options are:
  • Make a copy of the utility of interest and add the "-region" option in the code and compile the utility with a new name e.g. myWallShearStress and place it in FOAM_USER_APPBIN
  • Or, temporarily move the fluid fields from the fluid region to the main/default region, then run the utility on the case (no need for "-region") then move the fields back, e.g. see some example bash code below
Example bash code for option 2 to move fluid region fields to the main/default region:
#!/bin/bash
for i in $(foamListTimes)
do
    echo "${i}"
    cd "${i}"
    mv fluid/* .
    cd ..
done
Then run the utility.
Example bash code for option 2 to move main/default fields back to the fluid region:
#!/bin/bash
shopt -s extglob
do
    echo "${i}"
    cd "${i}"
    mv !(solid|fluid) fluid/
    cd ..
done
Chanikya_Valeti likes this.
bigphil is offline   Reply With Quote
Old   March 29, 2022, 12:20
Merlin Williams
Dear Mr Cardiff,
Thank you very much for this response. Sadly I already used option 2 and had to go through and move the files individually and this would have saved a lot of time. But I will absolutely use it again if I need to.
Thank you for your help
Merlin
bigphil and Chanikya_Valeti like this.
fsi 2-way coupling, post processing, vorticity
Artefacts in vorticity profile Goli OpenFOAM Post-Processing 0 March 31, 2021 02:34
Vorticity with pimpleDyMFoam Idasg OpenFOAM Post-Processing 1 March 6, 2019 04:16
Choice of numerical schemes for high accuracy in vorticity D.B OpenFOAM Running, Solving & CFD 1 February 5, 2018 10:44
3D vorticity contour shahzad_munir Main CFD Forum 0 May 1, 2014 02:34
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
