Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solidMechanics] Accelerate Solid Mechanics simulation (elasticPlasticSolidFoam)
Old   April 17, 2015, 10:44
Default Accelerate Solid Mechanics simulation (elasticPlasticSolidFoam)
David
davelgenuine is on a distinguished road
Hello everybody,
i've tried to accelerate my OpenFOAM Simulation/SolidMechanics/elasticPlasticSolidFoam (foam-extend-3.1). Therefore I use the Debugging mode from OpenFOAM and run my Simulation in parallel. At first, everything run smoothly but after I've changed one Parameter at the DU file (First order Derivation of Displacement):
topBrickDown
type solidContact;
master yes;
contactActive yes;
rigidMaster yes;
shadowPatch bottomBrickUp;
interpolationMethod ggi;
projectionAlgo visible;
projectionDir contactSphere;
correctionFrequency 500;
normalContactModel standardPenalty;
standardPenaltyNormalModelDict
to:
topBrickDown
type solidContact;
master yes;
contactActive yes;
rigidMaster no;
I got this error:
Time: 0.2
--> FOAM Warning :
From function GGIInterpolation<MasterPatch, SlavePatch>::calcAddressing()
in file /home/dave/foam/foam-extend-3.1/src/foam/lnInclude/GGIInterpolationWeights.C at line 424
polygonIntersection is returning a zero surface area between
Master face: 178 and Neighbour face: 863 intersection area = 0
Please check the two quick-check algorithms for GGIInterpolation. Something is missing.
--> FOAM Warning :
Master face: 208 and Neighbour face: 900 intersection area = 0
--> FOAM Warning :
--> FOAM Warning :
[1]
[1]
[1] --> FOAM FATAL ERROR:
[1] index -1 out of range 0 ... 257
[1]
[1] [0]
[0]
[0] --> FOAM FATAL ERROR:
[0] index -1 out of range 0 ... 257
[0]
[0] From function UList<T>::checkIndex(const label)
[0] in file /home/dave/foam/foam-extend-3.1/src/foam/lnInclude/UListI.H at line 124.
[0]
FOAM parallel run aborting
[0]
[1] in file /home/dave/foam/foam-extend-3.1/src/foam/lnInclude/UListI.H at line 124.
[1]
[1]
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[2]
[2]
[2] --> FOAM FATAL ERROR:
[2] index -1 out of range 0 ... 257
[2]
[2] From function UList<T>::checkIndex(const label)
[2] in file /home/dave/foam/foam-extend-3.1/src/foam/lnInclude/UListI.H at line 124.
[2]
[2]
[3]
[3]
[3] --> FOAM FATAL ERROR:
[3] index -1 out of range 0 ... 257
[3]
[3] From function UList<T>::checkIndex(const label)
[3] in file /home/dave/foam/foam-extend-3.1/src/foam/lnInclude/UListI.H at line 124.
[3]
[3]
[linux-a84b:30469] 3 more processes have sent help message help-mpi-api.txt / mpi-abort
[linux-a84b:30469] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Could anybody have an Idea, where this error come from and why?
I would be very grateful for any help.
David
davelgenuine is offline   Reply With Quote
Old   April 17, 2015, 11:02
David
Hello everybody,
I got this result per 1 outer Iteration (with 4 parallel Intel processors i7 4790k Quad Core)
My question is, did anybody know how to accelerate the solidMechanics Simulation? If I were right, the calculation calculateDivDSigmaExp.H take the most CPU-Time and maybe not been parallelized, if not, do anyone know how to parallelize it?
I would be thankful for any help
David
Last edited by davelgenuine; April 17, 2015 at 11:06. Reason: table not been shown
Old   April 28, 2015, 00:18
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi David,
For this warning:
FOAM Warning :
this normally suggests that something bad has happened with the solidContact boundary conditions. The warning itself comes from the GGI interpolation class which is used to pass the tractions from the slave surface to the master surface.
If you really do want to use the rigidMaster option, then I would recommend trying a lower penaltyScale value and/or more contact under-relaxation; this should help.
As regards calculateDivSigmaExp.H, yes the parallelisation of calculateDivSigmaExp.H is handled automagically by OpenFOAM: each proc performs the explicit field operations (fvc:: operations) just for its own cells and then there is some parallel transfer at the procToProc boundaries.
I suppose it is not very surprising that calculateDivSigmaExp.H takes a lot of time, though I am surprised that the DUEqn.solve() is so small; is this the case when you run more outer iterations?
Best,
Philip
bigphil is offline   Reply With Quote
Old   April 30, 2015, 10:00
David
Hi Philip,
thank you very much for your answer and suggestion.
I've tried a lower penalty scale till 1e-2, but the warning still came. What do you mean by "more contact under-relaxation", which parameter are they, in DU file or fvSolution file?
I also realised, that the warning come also because of the mesh of my geometries. I have two different mesh on two diferrent solid bodies. The top body is like a spitz of a cantilever beam and has a tetahedra mesh and commuted with the command "polyDualMesh 85 -overwrite" into polyhedra.
The pad in the bottom, which been penetrated by the spitz of the beam has a hexahedral mesh.
If I do checkMesh, the mesh of the top body has a problem with the maxSkewness > 4 and if I corrected it, also with a roughly mesh, then the checkMesh would say ok, because maxSkewnesS is < 4. But then I would get more warning from the solid contact.
With a more fine mesh, I would get fewer warning, but also still some of them, if the beam penetrate the pad more than 20 nanometer (about more then 0.2% of the epsilon, out from the elastic deformation and the beginning of the plastic deformation).
So, maybe you have more solution for the problem above?
According to the accelaration and your question:
It depends on which outer iteration is been calculated, my suggestion is also it depends on the sum of the inner iteration, by further simulation time and another divSigmaExp method (with surface), I also get another results (see picture, I've attached)
Simulation infos: Mesh generated by Salome, with 4 parallel Intel processors i7 4790k Quad Core, divSigmaExp: surface, relaxationFactors: DU=0,95 DepsilonP=0,95, d2dt2Schemes: Euler, ddtSchemes: steadyState
But still my question according to the accelaration, is there any way or solution to accelarate the calculation of the divSigmaExp? The divSigmaExp: decompose, should not faster than surface? I thought, because of the name "decompose" has a much better performance for a case of parallel run. I've tried it, with the snGrad(DU) "corrected" in fvSchemes file, but it gave a slower performance than the "surface" method...
I would be very grateful for your answer and help.
David
Old   July 13, 2022, 13:06
Richardpluff
CRI_CFD is on a distinguished road
Hi David,
I am facing a similar problem with this warning. Did you finally find a solution to avoid it?
Thanks in advance
CRI_CFD is offline   Reply With Quote
Multiphase simulation of solid particles max.kozak FLUENT 0 March 28, 2018 13:14
Solid Mechanics Solvers added to OpenFOAM Extend bigphil OpenFOAM Announcements from Other Sources 26 October 12, 2017 04:01
simulation with dpm : exchange of heat with a solid cdiako Fluent UDF and Scheme Programming 1 June 17, 2016 08:28
Reaction Force calculation in solid part in 2-way FSI simulation with CFX esbolico ANSYS 0 September 17, 2013 08:54
Simulation of fluid mechanics julyend Main CFD Forum 2 September 14, 2008 10:21
