July 21, 2021, 18:10 |
moving mesh + solids4foam
Rep Power: 4 |
Hello everybody,
I am writing about floating structures and their implementation in OpenFOAM. A few months ago I simulated a floating body with wave load with OpenFOAM and 6DoF. Actually I am trying to implement a fluid-structure-interaction. I am using the toolbox solids4Foam to solve this problem. Is it in principle possible to combine solids4Foam with floating objects or some moving mesh? The aim is a flexible, elastic or plastic floating body with wave load. I have already read the thread about sixDoFRigidBody motion, but there was no clear statement for me. If it is possible, which conditions I have to choose? I would be grateful about any help! |
July 28, 2021, 17:17 |
Philip Cardiff
Rep Power: 34 |
Hi Elstro,
As you know, 6DoF is a type of FSI where only the rigid motion of the solid object is considered. A solid deformation solver (like solids4foam) is basically a generalisation of a 6DoF solver as it allows rigid motions but also solid body deformations. So the solid solver replaces the 6DoF solver. This is possible in solids4foam; see for example the work of Luofeng Huang simulating floating ice sheets: https://www.sciencedirect.com/scienc...29801818320936. However, one of the challenges is restricting the rigid motions (just like in 6DoF) as the solid can start to float away. Philip |
July 30, 2021, 05:24 |
Rep Power: 4 |
Thank you very much! I am grateful for your answer and help.
January 17, 2024, 03:54 |
Runxin Luo
Rep Power: 4 |
Hi Elstro, I'd like to ask if you've solved this problem yet, I've gone to the paper and haven't got a clue so far
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
