[solids4Foam] How to set different thermal constants for different materials |
July 11, 2023, 03:35 |
Rep Power: 3 |
Hello all,
I want to use the solids4foam-2.0 to model heat balance. There are several different materials in my model. In the tutorial "hotCylinderPredefinedTFieldMultipleMaterials" , I have found how to define mechanical properties for different materials. However, I have not found how to define thermal constant, i.e. heat capacity and thermal conductivity for different materials. In the "thermalProperties" of that tutorial, there is only one group of thermal constant meanwhile it is not told which material this group of thermal constant belongs to. Is there a way to define thermal constant for different materials? Thank you! |
No option to set Vaporous Temperature in defining materials | maysmech | FLUENT | 0 | December 22, 2010 09:26 |
Help with GNUPlot | Renato. | Main CFD Forum | 6 | June 6, 2007 19:51 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
