[swak4Foam] Normal component of velocity in groovyBC
Old   July 12, 2016, 04:51
Question Normal component of velocity in groovyBC
Justin Wiegmann
SirIsaac90 is on a distinguished road
Hi Foamers!
I am struggling with with a pressure BC with groovyBC.
I want to define a groovyTotalPressure where p0Expression looks as follows:
p0Expression    "(U*normal() > 0) && (p < 99500) ? base - (mag(U)*a_max + b_max*mag(U)*mag(U)) : 99500";
Unfortunately, it does not work with the "normal()" multiplier. How to get the normal component of the velocities on a patch? Where is my fault?
I would be pleased if anyone can help me!
Regards
JW
SirIsaac90 is offline   Reply With Quote
Old   July 14, 2016, 03:43
Thumbs up
Justin Wiegmann
Hi!
Problem is already solved.
I did it with
U&normal().
At least it gave me the correct results.
Regards,
JW
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Velocity component averaging in ParaView jet_engine OpenFOAM Running, Solving & CFD 1 June 20, 2016 07:05
[swak4Foam] Set surface normal manually in groovyBC Mitchell Baum OpenFOAM Community Contributions 1 March 15, 2016 00:25
Surface normal velocity BC with zero gradient tangential, cylinder c_dowd OpenFOAM Running, Solving & CFD 0 May 25, 2013 07:22
Convergency y component velocity aryan Main CFD Forum 0 February 18, 2013 07:42
