[swak4Foam] Calculating a sequence of zone averages with swak4Foam
Old   November 6, 2015, 05:49
Default Calculating a sequence of zone averages with swak4Foam
K62
Martin Schmelzer
K62 is on a distinguished road
Dear forum,
I do simulations on a straight pipe and would like to extract pressure averaged over the radial plane at specific locations. Of course for the inlet and outlet patches one could use
patchAverage -latestTime p <patch>
and for single planes within the domain swak4Foam is a suitable option.
For that I am using this functionObject definition in controlDict
p0
      type swakExpression;
      valueType surface;
      surfaceName p0;
      surface {
          type plane;
          basePoint       (0 0 0.001);
          normalVector    (1 0 0);
          interpolate     false;
      verbose true;
      accumulations ( weightedAverage );
      outputControlMode timeStep;
      outputInterval 1;
      expression "p";
This gives me for a single basePoint, i.e. a single plane, the pressure averaged over the area of the plane. Using
execFlowFunctionObjects -latestTime
writes a nice output file in the postProcessing dir, such as:
#                  Time       weightedAverage
                 35000      1.86158477779654
However, I'd like to know if swak4Foam also offers the possibility to extract averages for multiple basePoints, i.e. multiple planes, and writes the result into a single file. Of course I am aware of the option to define multiple functionObjects. But, this gives also multiple output files. I am doing this so far and extracting the data using another python script. However, I'd like to know if swak4Foam offers a cleaner solution to my problem.
Any suggestions are more than welcome!
Thank you very much!
Martin
K62 is offline   Reply With Quote
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
